1989 toyota corolla sr5 overheating - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-19-2010, 02:58 PM   #1 (permalink)
View perk's Photo Gallery
Gen6 1989 toyota corolla sr5 overheating
I just bought this car from the guy has 195 thousand miles and its overheating. It didn't have a thermostat and the housing was covered in red silicone. Took all that off and now it has a a thermo, radiator cap, coolant and still overheating. I can't figure out what keeps causing it to overheat, also seems to heat up more when i down shift.
perk is offline   Reply With Quote
Old 12-19-2010, 03:18 PM   #2 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $352045
View Flashmn's Photo Gallery
Air in the system, broken water pump, blown headgasket.
Old 12-19-2010, 06:27 PM   #3 (permalink)
SCT
iAzn
SCT's Avatar
Gameroom cash: $316700
View SCT's Photo Gallery
Or clogged.
AE92 GTS Skirts | AE92 LE Trunk Garnish | 4AGZE Cryo-Blueprinted Crank
SCT is offline   Reply With Quote
Old 12-19-2010, 07:50 PM   #4 (permalink)
Rotary guy...
eage8's Avatar
Gameroom cash: $434050
View eage8's Photo Gallery
Or the radiator fan isn't turning on.
'81 BMW R65
Old 12-19-2010, 11:06 PM   #5 (permalink)
Gen6
Did a flush and the fan turns on when the key is in the on position. but it does seem that the radiator is clogged, the top holes are clogged. Also I cant get the thermostat housing back on. I got a thread lock and gasket maker for the housing but the bolts wont go in. The y seem to be cross threaded and at the opening and then threads inside. Does anyone know what the size is?
Old 12-20-2010, 05:10 AM   #6 (permalink)
Resident asshole
Flashmn's Avatar
M8x1.25 is the thread size for the thermostat housing.
Old 12-23-2010, 10:38 PM   #7 (permalink)
Thanks and i got another problem. When i hit the brake hard enough the engine stalls out. It also has an idling problem.
