4A-FE All-Trac Wagon severely injured...help! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-25-2010, 08:21 PM   #1 (permalink)
View frand004's Photo Gallery
My 1992 Corolla Wagon All-Trac is only running on 2 cylinders now (#3 & #4). #1 & #2 have 100 and 75 PSI (respectively) on compression test. Doing a leak test blowing air through plug hole has air coming out oil cap hole. Can't hear anything leaking in exhaust.
What is the next step? Am I missing a diagnosing step?
Do I pull engine, inspect and rebuild? Does it make more sense to just drop in another 4A-FE?
Does anyone have an idea of rebuild costs etc?
This car is a daily driver, no desire to mod.
Please give me your opinions.
frand004 is offline   Reply With Quote
Old 12-26-2010, 07:06 AM   #2 (permalink)
Gameroom cash: $150700
View 90 GP's Photo Gallery
Did you try putting a small quantity of oil in affected cyclinders and repeat compression test? If values increase it would indicate piston ring problems. Did you remove rad cap when injecting air into cyclinder to check for bubbles which would indicate blown head gasket.
90 GP is offline   Reply With Quote
The Following User Says Thank You to 90 GP For This Useful Post:
frand004 (12-26-2010)
Old 12-26-2010, 07:17 AM   #3 (permalink)
Here is a link with a posting on compression/leak test. It seems to confirm that leakage heard around valve cover area would be piston rings/cylinder issue. I read a post elsewhere where seafoam was used which freed up stuck rings and thus helped low compression issue.
http://www.toyota-4runner.org/classi...agnostics.html
Old 12-26-2010, 09:25 PM   #4 (permalink)
Responses
Thanks for the responses. It appears problem is head gasket. I'm going to tear it out this week and look at everything. I'm sure I'll post with more questions. I'll try to post pics.
Anyone looking to buy an All-Trac when its put back together? (Santa Barbara)
Old 01-15-2011, 11:58 PM   #5 (permalink)
ayang951's Avatar
Gameroom cash: $163050
View ayang951's Photo Gallery
is the all track a manual or auto? that makes a hugh difference in buy and sell in the corolla game... its more like you want to buy a auto and covert it manual, or buy a manual and do a clutch job either way its still involves taking the trans out... but yeah im interested in it if its a manual. im in the inland empire, kinda close to santa barbara and i always wanted a all track, i saw a all track wagon at the junk yard like 2 months ago, nothing wrong with it, just that the owner wanted a new car, and it was beautiful...
"I live my life one corner at a time, for those few seconds or less, im free."
~Mr.Yang
http://www.toyotanation.com/forum/sh...=1#post3365798
ayang951 is offline   Reply With Quote
Old 01-16-2011, 07:24 AM   #6 (permalink)
RogueMoog's Avatar
Gameroom cash: $314030
View RogueMoog's Photo Gallery
Ah, you should have rescued it!
RogueMoog is online now   Reply With Quote
Old 01-16-2011, 05:28 PM   #7 (permalink)
ayang951's Avatar
i know i wanted to, but the ecology wouldnt sell it to me, they said it was one of those cars that shouldnt be let back into the street, but they will sell you a crap mitsubishi eclipse with a billion dents and a kid who couldnt decide if he wanted to rice it or low ride it.. either way, my heart broke a little that day...
~Mr.Yang
Old 01-18-2011, 11:34 AM   #8 (permalink)
View datsa's Photo Gallery
I second that.
1988 Corolla SR5 AE95
datsa is offline   Reply With Quote
Old 01-20-2011, 11:26 PM   #9 (permalink)
Stuck. Any help/advice on getting the tranny back on the engine???? its got 1/2" to go...and won't move.
Old 01-21-2011, 02:19 AM   #10 (permalink)
ayang951's Avatar
what i normallly do is rock it like a quarter inch back and forth and keep pushing it in, it takes a bit but it always does the trick.
~Mr.Yang
Old 01-25-2011, 10:31 AM   #11 (permalink)
Started it up 1/23 and it runs fine! Drive tested 1/24 and there are some minor problems. I have an wire with black connector coming from the alternator...and I don't know where it goes. Will stop the lights from dimming in time with my blinkers!
I also have a bare spade from my AC compressor. I don't know if the connector got ripped off during the engine pull....?
Old 01-25-2011, 04:30 PM   #12 (permalink)
RogueMoog's Avatar
Do any of those connectors you're asking about look like this?
That's the oil pressure "dummy" sensor. It just makes a light go off if you have a DX model, or at least, only a light on the dash to tell you oil pressure is too low or something... Anyways if that's one of them, look behind the alternator, on the engine block. There's a connector that looks pretty much like a nail head; you slide this connector onto that. If I'm remembering correctly, it slides on in such a way that the black plastic is parallel to the engine block. Almost seems like it's not really connected (I found mine disconnected when I pulled my wiring harness away one dy recently).
Old 01-31-2011, 08:46 AM   #13 (permalink)
Thanks RogueMoog! That took care of the electrical issue.
So, the problem now: I drove the car to a buddy's and upon trying to leave, the car wouldn't start. One the the injectors was leaking fuel (guess I pinched an O-ring on the install). I put in new o-ring, and it won't start. I'm cranking, getting fuel, but no spark. I'm getting power from the ignition to the distributor, but thats all I know. What should I test here?
Pull the ECM? It seems weird that the injector issue somehow turned into an electrical one. Any advice?
Old 02-05-2011, 10:37 AM   #14 (permalink)
saga cont
So I replaced distributor, cap etc. No spark. How is the distributor grounded?
Old 02-06-2011, 11:43 PM   #15 (permalink)
diagnosis
I have spark.
I also cleaned up the injectors and put all new o-rings / spacers on them. The engine still isn't firing, and it appeared for a while like it was being flooded with fuel. Possible fuel pressure regulating valve?
I'm not sure what to check next. ideas?
