It usually is a ground problem in this case. Make sure the wire for the ground is the same size as your power wires. And also make sure the cables aren't too long to the ground, under 3 feet long is best. Shorter the better.
Now the best place to ground in this car I found, is using the bolts to the back seats, the lower bolts that bolt right into the car chassis. Sand down some of the paint to bare metal right where the ground wires are bolting on to get best connection. And it actually doesn't matter if you ground both of them to each other, it all goes to the same place any way. Just make sure it's a good tight clean connection. You'll be fine. :p
One way to test your remote wire is using a test light or a multimeter. With everything hooked up properly, turn on your CD Player, and see if there's is power going to your REM connection on the amplifier. Even if it's a small amount, that's all it needs to trigger the amp to turn on. And typically most amps have at least a small LED that comes on when the amp is powered and on.
Hope that helps. Been doing this stuff for years. :p
