I definitely recommend taking the engine/tranny combo out from below. It snagged on every thing when I hoisted it up from the hood.
It would probably be impossible to lift the engine out with the hood in place. Its just four 12mm bolts and one washer hose to remove the hood.
The tranny, t-case and engine all come out together. You then remove a lot of bolts and brackets to get the bellhousing from the engine block.
I got quoted 12 hours from my Toyota dealership for a clutch job, if nothing goes wrong.
It took me days to get the engine out the first time, lifting it up with a forklift and two extra hands, and a long time to get it back down again.
The second time I rented a bay with a lift. YouŽll have to disassemble the front suspension, remove the subframe and then lower the engine/tranny/t-case package down.
It took me 15 hours with handtools to change the clutch, replace all oils and filters, replenish coolant, grease everything I could think of greasing, replace a panhard bushing, get everything put back together and out of the bay. And thats with anti-seize and a few new bolts from the last time I tore the thing apart. If the bolts had rusted heads or if they had been seized it would have taken forever.
You can expect to spend a long time the first time you need to get to the clutch, a pair of helping hands is very good to have when you start rotating and pulling the tranny from the engine.
