Opinion on Lowering springs - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-19-2011, 03:55 PM   #1 (permalink)
View ae924af's Photo Gallery
I know this topic has been talked about over and over again but I am just trying to understand a little more about what types are good and which ones arent. I am wondering what are the pros and cons between B&G springs, Ebachi, Apex, and other springs? what are other options and how well to they work and last?
ae924af is offline   Reply With Quote
Old 01-19-2011, 05:47 PM   #2 (permalink)
Gameroom cash: $347685
View SuperRA's Photo Gallery
I have Intrax and they are ok. The drop in the front was too low for my taste and about 3/4" lower drop than the rear. I made a spacer to raise the front and even it all out and it's much better. I'd go with another brand if you have the money. I paid a discount price for my set, hence the extra work.
SuperRA is offline   Reply With Quote
Old 01-19-2011, 08:05 PM   #3 (permalink)
KDM is in
REN69's Avatar
Gameroom cash: $273221
View REN69's Photo Gallery
you're right... it has been covered a lot. Basically APEX has been everyone's favorite for a long time for a reason, great quality and performance... I had them on both my GTS's and yeah, win.
Ground Control coilovers would be your best bet if you have a bigger suspension budget... now all you have to work on is what struts to go with.
Old 01-19-2011, 09:46 PM   #4 (permalink)
Rotary guy...
eage8's Avatar
Gameroom cash: $434050
View eage8's Photo Gallery
suspension travel is an issue on AE92s. all lowering springs I've seen (except maybe eibachs) lower it too much and you'll hit the bump stop.
APEXs do look nice, and are cheep, and perform well... but the actual handling is sub-par.
the best way to go is either some nice coilovers (JIC?) or get some ground controls and not lower it as much as you'd probably like. (or go with eibachs and have the same issue, not very low)
more important is to get a nice set of struts.
'81 BMW R65
Old 01-19-2011, 10:19 PM   #5 (permalink)
What would be a nice set of struts?
Old 01-19-2011, 10:45 PM   #6 (permalink)
Rotary guy...
eage8's Avatar
koni yellows
or, a cheaper option is 2nd gen MR2 KYB AGX inserts in GT-S struts in the front + KYB GR-2s in the back, but it won't be as good.
JIC coilovers also have nice dampers. Teins aren't as good, but they're decent.
'81 BMW R65
Old 01-19-2011, 11:15 PM   #7 (permalink)
View NZAE92's Photo Gallery
AE92
I have jamex super-lows in the front with ae111 shocks, they don't hit the bump stops and don't rub the guards and are really stiff.
Also have jamex super-lows in the rear with monroe gas reflex shocks.
it handles really well but monroes are pretty pricey but definitely beat the ae111 struts that were out of gas, which hit the bump stops and rubbed the guards.
NZAE92 is offline   Reply With Quote
Old 01-20-2011, 04:05 AM   #8 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $352045
View Flashmn's Photo Gallery
And thats not all, when you "slam" an AE92, your control arms start going into an undesired angle, which makes the handling of the car real shitty.
Old 01-20-2011, 08:20 AM   #9 (permalink)
Rotary guy...
eage8's Avatar
only if you have suspension soft enough to move and a sane amount of camber...
I run 525 lbs springs up front with -3.5* of camber and it's great, unless it's raining of course... then it's just dangerous.
I think you'd be surprised. the springs probably aren't nearly as stiff as you think they are... you're probably just on the bump stops already at rest and using them as a spring... have you actually looked to see where you sit compared to the bump stops?
I also doubt any Monroe damper was "pricey"...
'81 BMW R65
Old 01-20-2011, 11:21 AM   #10 (permalink)
Resident asshole
Flashmn's Avatar
I wasnt talking about camber, your lower control arms start to be in a bad angle (pointing upwards), which affects handling badly, such as bump steering etc.
I have -50mm kit on mine and its JUST at the limit.
Old 01-20-2011, 11:41 AM   #11 (permalink)
Rotary guy...
eage8's Avatar
I know. It affects handling because it messes up the camber curve. When the arm moves up it moves the bottom of the knuckle further away which adds positive camber... which is bad. by increasing negative static camber, when it adds positive camber it's not as big of a deal.
Adding stiffer springs also helps because the suspension doesn't travel as much which decreases it's affect.
the same thing happens with the tie rod radius, stiffer springs helps here too.
'81 BMW R65
Old 01-20-2011, 12:19 PM   #12 (permalink)
Resident asshole
Flashmn's Avatar
Doesnt help removing bump steering which is caused by the tierods.
Old 01-20-2011, 12:32 PM   #13 (permalink)
Rotary guy...
eage8's Avatar
camber doesn't, no, but stiffer springs do.
'81 BMW R65
Old 01-20-2011, 12:43 PM   #14 (permalink)
ayang951's Avatar
Gameroom cash: $163050
View ayang951's Photo Gallery
so uhms... i have some dropzone on my car, dont recommend the shocks though they a little too soft but then again i bought it for lifetime warranty for commuting... but i got the springs and shocks for a 93-96 corolla and installed them on my 91 corolla... if your interested i have a write up, just click on the link below my post.
"I live my life one corner at a time, for those few seconds or less, im free."
~Mr.Yang
http://www.toyotanation.com/forum/sh...=1#post3365798
ayang951 is offline   Reply With Quote
Old 01-20-2011, 04:03 PM   #15 (permalink)
Gameroom cash: $134355
I don't think I've ever hit the bump stops on my ae92 with ST's and GR2's....
Tags
lowering springs
