1992 corolla 4afe valve cover pic - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-23-2011, 04:54 PM   #1 (permalink)
redneck engineer
lemegacool's Avatar
Gameroom cash: $233405
View lemegacool's Photo Gallery
hey all!
i did a timing belt change a month ago on my girlfriend's 1992 corolla
the car had 166307 KM at the change (103338 miles)
i and my mechanic friend was completely stunned when i took off the valve cover!!!
this is what regular oil changes do
1994 camry v6 5 speed swapped
holset hx35w rebuild/polishing in progress :P
cardomain: http://www.cardomain.com/ride/3872430
lemegacool is offline   Reply With Quote
Old 01-23-2011, 05:42 PM   #2 (permalink)
DX? Doesn't seem deluxe!
Brown_Muscle's Avatar
View Brown_Muscle's Photo Gallery
wow! that's clean. does your girlfriend use synthetic or dino oil??
-Phil
1992 Corolla DX 5-speed, GTS front and rear sway bars, 15" Motegi Racing rims with 205/50R15's, Aftermarket strut bar, JVC Head Unit, Pioneer Speakers, 10" Polk Sub+Amp, Front Lip Mod.
1982 Ford LTD-S Police Car 351 Windsor
Brown_Muscle is offline   Reply With Quote
Old 01-23-2011, 06:13 PM   #3 (permalink)
RogueMoog's Avatar
Gameroom cash: $314030
View RogueMoog's Photo Gallery
Fantastic! Reminds me, mine is due for a change soon. I bought dino/synthetic blend, 20w-50, then I'll go to full synthetic for the next change. Need to source out & fix some oil leaks...
RogueMoog is online now   Reply With Quote
Old 01-23-2011, 06:34 PM   #4 (permalink)
redneck engineer
lemegacool's Avatar
crappy crappy dino oil lol
now she is buying castrol gtx 5w30 and i'm doing her oil changes every 5000kms now since a friend of mine works at toyota i'll be using oem toyota oil filters as well
Old 01-23-2011, 09:32 PM   #5 (permalink)
Rotary guy...
eage8's Avatar
Gameroom cash: $434050
View eage8's Photo Gallery
there is no reason to put 20w50 in a corolla... it'll just wear the engine down at start up and not oil properly.
'81 BMW R65
Old 01-23-2011, 10:01 PM   #6 (permalink)
tacosteelersman's Avatar
Gameroom cash: $170177
View tacosteelersman's Photo Gallery
Don't be supprised you own one of the best toyota engines ever made in the way of reliability hands down!! (just my opinion)
95.5 Tacoma 2.7 300,000
91 Corolla 1.6 180,000
96 Avalon 3.0 190,000
95 Ford Aspire 1.3 125,000
tacosteelersman is offline   Reply With Quote
Old 01-23-2011, 10:15 PM   #7 (permalink)
RogueMoog's Avatar
In my owner's manual and the Toyota factory service manual, it has a chart with temp ranges (in both F and C) and the viscosity recommended. It says at the bottom of the chart, "temperature range anticipated before next oil change." Normally I'd go with 10w-30, but in the All-Trac/4WD owner's manual & FSM it says 10w-30 is for 0 F to about 40 F. I'm in Florida... it rarely gets below 30 F here, and rarely that temperature outside when I'm driving (also my wagon is garaged), so that's why I'm going with 20w-50 (70 F to over 100 F). It may be different than the other 6th gens, I don't know. Really I ought to go with 20w-40 from what the manual says, but I don't think I've seen that oil on the shelf recently.
The owner's & FS manuals both say to use 75w-90, 80w-90, or 90 gear oil for the transmission / transfer case / rear diff. for these wagons. I'm guessing that's also different than what the non-All-Trac/4WD sedans, wagons, etc use...
Old 01-23-2011, 10:22 PM   #8 (permalink)
Drain the oil on the dam thing and go.. This SOB is bullet proof, It laughs at viscosity differences.
Old 01-24-2011, 01:27 AM   #9 (permalink)
View eberbs1's Photo Gallery
My motor after 270k km
eberbs1 is offline   Reply With Quote
Old 01-24-2011, 02:12 AM   #10 (permalink)
SCT
iAzn
SCT's Avatar
Gameroom cash: $316700
View SCT's Photo Gallery
You bastards making me want to take off my valve cover and take pictures of it now! LOL
My '88 is sitting at 266992 miles, awaiting the timing belt replacement to get done. The valve cover was taken off only once in it's lifetime because one of the spark plug hole gaskets started leaking. All the rubber became fossils. I may have to change them out soon. When I changed the spark plug hole gaskets, I think I had put them upside-down... But it's been close to fine over the past 3 years or so.
My car has always been using Mobil1 Fully Synthetic 5W30, btw. Just recently, I've been using Engine Restorer, which actually works IMO. But I'm beginning to think some of the solid additives that looks to be in it could be clogging the filter. Kinda doubt it, but possibilities.
AE92 GTS Skirts | AE92 LE Trunk Garnish | 4AGZE Cryo-Blueprinted Crank
SCT is offline   Reply With Quote
Old 01-24-2011, 05:27 AM   #11 (permalink)
redneck engineer
lemegacool's Avatar
wow thats also helluva clean for 270k km !!!
take it off lol only held by 3 nuts lol i would like to check on my 1mzfe v6 but removing both cover is a pita lol
Old 01-24-2011, 07:27 AM   #12 (permalink)
Bitter's Avatar
Gameroom cash: $559100
View Bitter's Photo Gallery
Oils have advanced a lot since that manual was written. you can run 5w-30 year round just fine, even 0w-30.
Old 01-24-2011, 10:23 AM   #13 (permalink)
Had my valve cover off to change sparkplug tube seals and the main valve cover seals.
Old 01-24-2011, 12:59 PM   #14 (permalink)
View BandoTRD's Photo Gallery
LoL true thing you guys are makin us take our covers off jajaja, anywyz I dont doubt mines this clean too ive been using Castrol Syntec 10W40 since day 1 I got my GTS and its about to be 3 years next july and its done wonders in power and gas mileage too and ive never open my valve cover
BandoTRD is offline   Reply With Quote
Old 01-24-2011, 11:26 PM   #15 (permalink)
SCT
iAzn
SCT's Avatar
Imagine this, except the rubbers being harder than a rock but easy to break apart. You'd have what I had.
I'm going to change the gaskets out when I get new plugs. My first plug is always sleeping in oil, not flooding oil, just some.
