Modifying a 20V oil sensor for SX - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-25-2011, 09:40 PM   #1 (permalink)
View Alf6's Photo Gallery
Hi, I have an Australian, October built 1989 SX Corolla Hatchback, fitted with a 20V Silvertop by the previous owner. He did not persue doing anything with the oil pressure instrumentation.
I am led to believe that the 20V oil sensor runs to a dashboard light, whereas the '89 SX has a pressure gauge mounted in the dash board. Therefore I will need to fit the 20V with the original engine's type of oil sensor. Is this correct? The original engine was a twincam 4A1621xxx
If so, I have two questions - firstly, is the size of the oil sensors thread size/pattern the same (interchangeable) or do I need to do something before installing. Secondly, how do I go about removing the oil sensor from the 20V that is currently in the car.
Thanks in advance, Alf
Alf6 is offline   Reply With Quote
Old 01-26-2011, 09:22 AM   #2 (permalink)
Rotary guy...
eage8's Avatar
Gameroom cash: $434050
View eage8's Photo Gallery
yup, 20V is switch type (like the 4AFE). It's down underneath the powersteering pump, it's just a bolt that you unscrew to get it out. the one from you old engine looks like a mushroom, you just screw it right in in it's place. the threads are the same. the connector should even hook right up.
'81 BMW R65
