From a topic I started in which this was brought up... the image is looking at the engine as though you were sitting in the car, if that makes sense. Or, sort of an overhead view...
Originally Posted by SCT
For the starter, you access the two wires connected to it from the bottom. As for the mount bolts, one is access from the bottom while the other is accessed through the top driver side on the bellhousing. Once loose, the starter can be maneuvered out through the top of the driver side. No need to remove any hose, just need to bend one of the coolant hose out the way a bit. Simple. Provided a picture:
is it possible to get to the alternator without having to get under the car? could you unscrew the wire by feel w/o actually seeing the nut? also it seems obvious to have ez acess one should remove the intake manifold but would you be able get at it from the side by removing air box?
Im assuming there is a gasket between the intake mani and the engine, if so, is it necessary to replace?
