the adapters are really cheaply made, and you might want to buy a new shrader valve... but very careful, if they get over tightened, it can really be a bitch to remove a damaged one... sounds like you lost most the charge, I think it is set to about 5 psi, to engage the compressor safety switch.. I have to chage my daughters a/c on her 19993 camry,, some dumbass who owned it before changed it from r-12 to freeze 12, now I need to convert it to r134a. It stopped cooling an dhtink it must be leaking.. altough the compressor is runnung..
I wil probably just replace the filter/drier. Put Ester oil, and and r134a in. along with the r134a conversion kit adapters. That damned freeze-12 has some othet type carppy adapters on it. also, the refrigerant conversion sticker is ont he hood, but everything they wrote in wore away with weather and age. So, I have no clue what they put in the a/c.
I stil have a few cans from a case of r134a from costco. The auto parts store told me they just started charging a $10.00 per can deposit for the environmental dooshbags scumbags..
for a/c refrigerant.
1989 Toyota Corolla SR5, Carb.
1993 Camry LE
