Over heating question
I have an '89 Corolla auto with 140,XXX. All of the sudden it started overheating the same time the radiator rotted out. Got real hot, real quick one time. New radiator but now it boils still. Fans work. Water pump must otherwise why would the radiator boil right?
I pressure tested the head and cylinder #1 = 200psi, #2 = 165psi, #3 = 175psi & #4 = 200 psi.
Could a blown head gasket cause the overheating or did the overheating warp the head and blow the gasket?
No oil in anti-freeze but I believe there is anti-freeze in the oil.
I can replace the head gasket but want to make sure there is not an underlying cause that I'm over looking.
Thanks,
1990 Corolla Wagon 4A-FE, 170K & 3rd engine...
1996 Camry Wagon V6 , 140K
