Need help Front end shudder
need help diagnosing a front end shudder. it only happens when i first start it theres a small shudder, and also when i take off from first under heavy acceleration. basically whenever i put alot of torque on the car it will shudder violently. it's fine in neutral and when coasting in gear but if i put the pedal to the floor it will shudder in any gear. it used to do it only when i was stuck in deep snow, it got so bad today i couldnt even use the accelerator at all until i washed it and it went away but now is back again slightly
