88 corolla gts - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-08-2011, 01:08 PM   #1 (permalink)
View cargirl83's Photo Gallery
Gen6 88 corolla gts
I have just got an 88 corolla gts. It has blown head gasket. Possible cylider problems. It is in great condition inside and out besides it overheating. I am wanting to poss sell this car. Is there any collectors out there that might want this car, or can tell me what this car is worth? Im not sure if I should fix it up or buy a newer car. What does anyone think about it.
cargirl83 is offline   Reply With Quote
Old 02-08-2011, 02:19 PM   #2 (permalink)
SCT
iAzn
SCT's Avatar
Gameroom cash: $316700
View SCT's Photo Gallery
IMO, I say fix it. Still a reliable car. The blown headgasket would make it overheat, btw.
The car's not highly sought after like some RWD japanese car or something, a car that would be made a tuner or whatever. Although, the GTS is becoming harder to find. Like cars that are 40 year old and older now, maybe it'll join that rank when it gets that old.
AE92 GTS Skirts | AE92 LE Trunk Garnish | 4AGZE Cryo-Blueprinted Crank
SCT is offline   Reply With Quote
The Following User Says Thank You to SCT For This Useful Post:
cargirl83 (02-09-2011)
Old 02-08-2011, 07:17 PM   #3 (permalink)
plyr503's Avatar
View plyr503's Photo Gallery
I'd have to agree. Fix her and drive her. I've never seen one selling for much more than 1500 on craiglist in my area......
plyr503 is offline   Reply With Quote
The Following User Says Thank You to plyr503 For This Useful Post:
Old 02-08-2011, 08:56 PM   #4 (permalink)
KDM is in
REN69's Avatar
Gameroom cash: $273221
View REN69's Photo Gallery
Collectors? lol this is not a collector's car by any means... I hope you didn't pay too much for it.
I'd say fix it and drive it, motors are pretty cheap if you can find one.
The Following User Says Thank You to REN69 For This Useful Post:
Old 02-09-2011, 10:19 AM   #5 (permalink)
Gen6 motors
Well here is the thing this car has a carb on it. I am wanting to put a diff motor in it. What kinds of motors will fit in this car? Was thinking maybe celica motor or something like that. Anyone know what will fit in it and wont cost me an arm and a leg, not that I need them or anything,lol.
Old 02-09-2011, 11:28 AM   #6 (permalink)
Rotary guy...
eage8's Avatar
Gameroom cash: $434050
View eage8's Photo Gallery
stock carb or aftermarket?
If it has a carb it's probably not a GT-S... it's probably an SR5 coupe.
'81 BMW R65
The Following User Says Thank You to eage8 For This Useful Post:
Old 02-09-2011, 11:51 AM   #7 (permalink)
Gen6 Gts
Well I think its a GTS cause I googled all the 88 toyota corollas cars til I found one like mine and it said it was a GTS. It is stock carb, no mods on it at all.
Old 02-09-2011, 12:09 PM   #8 (permalink)
Rotary guy...
eage8's Avatar
it's an SR5 like mine
Here is my '89:
'81 BMW R65
Old 02-09-2011, 12:19 PM   #9 (permalink)
Gen6 confussed
Its hard to tell cause the pic I found on google is just like mine it said gts but ur pic looks like it 2 idk. what is the diff between the two?
Old 02-09-2011, 12:24 PM   #10 (permalink)
Rotary guy...
eage8's Avatar
there are a lot of small differences, but the main difference is SR5s have slower carbureted engines GT-Ss have fuel injected engines have have about 30 more hp
'81 BMW R65
Old 02-09-2011, 12:38 PM   #11 (permalink)
Ok I looked up some info I im sure ur right it is a SR5. Mine doesnt have a pass side mirrow tho u know about that? The mirror has like a hole in it made like that.
Old 02-09-2011, 01:24 PM   #12 (permalink)
View Vin-ce's Photo Gallery
since we are on SR5's my headlights don't work except for the high beams how would li check to get that fixed up
Vin-ce is offline   Reply With Quote
Old 02-09-2011, 08:55 PM   #13 (permalink)
SCT
iAzn
SCT's Avatar
All parts from a GTS can be installed onto the SR5 since they're both the same car, except the GTS being a bit more hopped up in terms of having an fuel injected engine and a factory body kit which includes side skirts and a wing.
Can you post pictures of your car?
Old 02-11-2011, 04:02 AM   #14 (permalink)
Vroom?
freakinbox's Avatar
View freakinbox's Photo Gallery
GTS also has rear disc breaks. Carb = SR5 either an 88 or 89 since after that they went with EFI on them. Given that it has the 4af and it has a blown head gasket it explains the over heating issues. Other things that can make it run rough is a bad carb or vacuum lines or fittings being damaged such as snapped off which was my cars issue with I parked it. So don't get stressed if it still runs a little rough after the head gasket issue is sorted. Other than that these cars can take a good beating and still be reliable. If you watch the oil and antifreeze in them they can even go months with a bad head head gasket and still run perfectly after you change it.
I would say the worth can vary, it depends on the condition of everything else other than the head gasket. If the body and interior is in great shape I'd say 1500 - 2000 but no more than that.
1989 Corolla sr5, 4af, 1990 gts seats, TRD short shifter.
http://www.cardomain.com/ride/2061750
freakinbox is offline   Reply With Quote
The Following User Says Thank You to freakinbox For This Useful Post:
cargirl83 (02-11-2011)
Old 02-11-2011, 09:33 AM   #15 (permalink)
Gen6 Replacing motor?
aNYONE KNOW WHAT YEARS AND WHAT KINDS OF ENGINES I CAN PUT IN THIS CAR THAT WILL FIT WITHOUT MAKING MODS. WANT TO START LOOKING AT JUNK YARDS FOR A USED MOTOR.
