My 1990 SR5 Coupe, 4AFE, has a short that is draining the new battery during periods of no use. The short is not strong enough to light a test light. It does show 13+ volts on an analog voltmeter. A digital ohmmeter reads between 1600 to over 2000 ohms. When I unplug the alternator, this reading drops to 600 ohms. Because unplugging makes a difference, I am thinking bad diode.
In order to test further I wanted to unplug the main fuse to the alternator from the harness at the battery post.. These three fuses are very stubborn. I can't get them to budge. I have exerted a lot of effort to no avail. I guess they are corroded into their sockets. Any tricks to removing them. I soaked them in WD40 but got nowhere.
