what to build a 4age for my car - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-09-2011, 03:09 AM   #1 (permalink)
View slammedcorollawagon's Photo Gallery
im thinking about building a 4age whith 4af head for my 89 corolla wagon. what computer would i use? what would i have to do to put that head on that block?
slammedcorollawagon is offline   Reply With Quote
Old 02-09-2011, 07:54 AM   #2 (permalink)
View aj_gilbs's Photo Gallery
umm, why?
and someone will have to correct me if I'm wrong, but I don't think that will even work.
aj_gilbs is offline   Reply With Quote
Old 02-09-2011, 10:40 AM   #3 (permalink)
Blof-fan's Avatar
Gameroom cash: $294850
View Blof-fan's Photo Gallery
What do you think you will gain? What do you want to change with that cylinderblock? Compression ratio? And what are your plans for the head?
I think you haven't really done much research into this yet right?
Because it will fit alright, because they both use basically the same cylinderblock!
(only diffenence is the cranckshaft that has 6 bolt for the flywheel instead of the 8 bolt that the 4A-GE uses)
So the answer to your question is:
You don't have to change a thing, it will all fit perfectly together.
And about the computer: If you are going with the (carbed) 4A-F head, you don't even have to use a computer
If you are talking about putting and EFI (electronic fuel injection) on your 4A-F head. Don't bother. Toyota has already done all the work for you!
Just buy a 4A-FE.
It has basically the same cylinderblock as the 4A-GE uses and has the 4A-F head with fuel injection.
Driving : '92 Toyota T19 Carina E GTi
Repairing : '92 Toyota AE92 Corolla Hatchback GTSi
Restoring : '88 Toyota AE92 Corolla Coupé GT-S
My personal website: http://www.corollaae92gts.nl
Blof-fan is online now   Reply With Quote
Old 02-09-2011, 04:10 PM   #4 (permalink)
i dont wanna go fuel injected. and i wanna do this cause i have a ported polished 4af head just sitting around that i wanna use
Old 02-09-2011, 08:49 PM   #5 (permalink)
SCT
iAzn
SCT's Avatar
Gameroom cash: $316700
View SCT's Photo Gallery
Isn't there carb kits for fuel injections? Or something like that...
You might just well take that Ported & Polish 4AF head and stick it onto the block you have in your car now. They're virtually all the same block.
AE92 GTS Skirts | AE92 LE Trunk Garnish | 4AGZE Cryo-Blueprinted Crank
SCT is offline   Reply With Quote
Old 02-10-2011, 03:48 AM   #6 (permalink)
i wanna build a motor for turbo and thats the block i started to look at
Old 02-10-2011, 02:42 PM   #7 (permalink)
BackYard Engineering
Evo_lucian's Avatar
Gameroom cash: $102535
View Evo_lucian's Photo Gallery
I will be frank with you.
1- you will not be building a 4age when you put your 4af head on a 4age block. It will still be a 4af with slightly higher c/r.
2- 4age will out flow your "port and polish" 4af head.
3- if you swap on a 8 bolt fly 4age block, you would have to get matching flywheel, clutch and pp and a few lil bits. In my opinion in the end the costs will out weigh the gains.
4- in your first post you asked about computer choice and then you say you don't wanna go efi ?
5- can you tune carbs ?
The only thing in life worse than being talked about is not being talked about
My website updated 6/May/11
http://budgetracer.webs.com/
Evo_lucian is offline   Reply With Quote
