4A-GZE / 6spd? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-19-2011, 06:40 PM   #1 (permalink)
Donald's Avatar
Gameroom cash: $201420
View Donald's Photo Gallery
4A-GZE / 6spd?
Was there ever a 6 speed mated to a 4A-GZE from the factory, AE92 or AE101?
Why I ask is on my 4A-GZE (AE92 version) into FX-16 swap, I cannot get reverse, but I seem to have 6 forward gears.
I haven't actually taken the car out onto the road yet to see for sure if there are actually 6 forward gears, but the shifter seems to go into 6 slots, and the car moves forward each time.
'88 Corolla, AE92 SR-5, 7A-FE swap/GT-S suspension
'87 Corolla, AE82 FX-16, 4A-GZE swap (autocrosser)
'03 Tundra 4X4 Access Cab, (FX tow vehicle/Home Depot runner)
Modification: Changing something to what you thought it should have been from the start!
Donald is offline   Reply With Quote
Old 02-19-2011, 07:21 PM   #2 (permalink)
Gameroom cash: $164205
View kwint's Photo Gallery
Maybe its from an ae101 or newer? I thought 6 speeds only came after the ae92.
kwint is offline   Reply With Quote
Old 02-19-2011, 10:20 PM   #3 (permalink)
SCT
iAzn
SCT's Avatar
Gameroom cash: $316700
View SCT's Photo Gallery
I think reverse for the 6spd is from neutral central, hard left and up. Haven't heard of 6spd being on 4AGZEs, only blacktop 20vs.
AE92 GTS Skirts | AE92 LE Trunk Garnish | 4AGZE Cryo-Blueprinted Crank
SCT is offline   Reply With Quote
Old 02-20-2011, 09:27 AM   #4 (permalink)
Donald's Avatar
Yes. That is what I was thinking too.
Plus, this is supposed to be an "E" series gearbox. I've never heard of any of those being 6 speed.
I am about to do some experimentation in a few moments. I'll post my findings.
Old 02-20-2011, 11:53 AM   #5 (permalink)
KDM is in
REN69's Avatar
Gameroom cash: $273221
View REN69's Photo Gallery
Not that I recall ever seeing... all GZE's came with E transmissions and I don't recall ever seeing any 6sp E transmissions before, not even on MR2's.
Old 02-20-2011, 03:06 PM   #6 (permalink)
Donald's Avatar
Ok. No sixth gear.
The problem was the shifter cable bracket on the gearbox. I had to drill some new holes and reposition it to get full linkage travel. I now have 5 speeds and reverse.
http://www.toyotanation.com/forum/sh...68#post3483868
Old 02-20-2011, 07:11 PM   #7 (permalink)
Gameroom cash: $134355
typically the shifter cables are different on the E series transmissions....
in the aw11 you can get around it if you modify the shifter bracket to fit onto an E series -- allows you to use C series shifters & bracket on the E series and it will all work fine.
if the trans was heavier than god, then it's an E series (typically the rear mount has to be modified to make fit... from what I've heard from other ae92 owners). If it felt like a C series then it was a C series. (another quick way to tell is all E series have a metal hardline that runs oil form one section of the trans to another... and this line runs externally on the bottom of the engine).
Old 02-20-2011, 08:57 PM   #8 (permalink)
Donald's Avatar
Yes, and yes.
No.
(another quick way to tell is all E series have a metal hardline that runs oil form one section of the trans to another... and this line runs externally on the bottom of the trans).
Yes.
