No Heat 1991 corolla - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-21-2011, 08:31 PM   #1 (permalink)
View pwehr's Photo Gallery
1. Heater core is non restricted, Water runs through easy with garden hose conected
2. Temp valve opens and closes properly, Tested by blowing through.
3. Radiator holds presure with cap on.
4. Upper and lower heater hoses seem to get hot.
5. Blower motor inside car works fine.
6. Termostat is currently out, but engine is reaching temp
7. Radiator is new.
I've been doing alot of this
pwehr is offline   Reply With Quote
Old 02-21-2011, 09:46 PM   #2 (permalink)
Rotary guy...
eage8's Avatar
Gameroom cash: $434050
View eage8's Photo Gallery
I would put t he thermostat back in. My heat didn't work at all when my thermostat had a bad gasket...
are you putting it on re-circ? it helps to pull in the warmer interior air to heat up.
'81 BMW R65
The Following User Says Thank You to eage8 For This Useful Post:
pwehr (02-21-2011)
Old 02-21-2011, 10:50 PM   #3 (permalink)
Had the thermostat a new aftermarket thermostat in a one point, but didn't have heat. Maybe I should try a oem one from the dealer. Tried recirc doesn't make a difference, heat is ice cold in 60 degree weather.
Old 02-22-2011, 03:24 AM   #4 (permalink)
SCT
iAzn
SCT's Avatar
Gameroom cash: $316700
View SCT's Photo Gallery
Is the water pump working? There was one car, a mid 90s Ford Taurus, that I had to change a water pump. It was so corroded, all that was left to pump anything was the shaft. All the blades were pretty much gone.
AE92 GTS Skirts | AE92 LE Trunk Garnish | 4AGZE Cryo-Blueprinted Crank
SCT is offline   Reply With Quote
The Following User Says Thank You to SCT For This Useful Post:
pwehr (02-22-2011)
Old 02-22-2011, 06:17 AM   #5 (permalink)
Gameroom cash: $150700
View 90 GP's Photo Gallery
I agree on replacing thermostat. You could also have air in the system. With engine cold park on incline (front end higher) remove rad cap and make sure antifreeze is to filler neck. Start it up ,turn heat on high and let it run till engine is warmed up. If any air is trapped that should burp it out.
90 GP is offline   Reply With Quote
The Following User Says Thank You to 90 GP For This Useful Post:
pwehr (02-22-2011)
Old 02-22-2011, 07:58 AM   #6 (permalink)
Interesting you mention water pump, I keep telling myself if it doesn't leak it has to be working. I had the engine running at operating temp. with the radiator full, both heater hoses off at the heater core with vise grips clamping the lines and couldn't get much water flow. I don't know whether the sys. has to be totally closed and under pressure in order to see flow. I'm also thinking it maybe the water pump, just wish there was a for sure test before throwing to many parts at it.
Old 02-22-2011, 08:15 AM   #7 (permalink)
With the thermostat out and engine at normal operating temperature, shouldn't my heater work as long as the cooling sys. is burped and not air locked?
Old 02-22-2011, 09:32 AM   #8 (permalink)
View nizzehult's Photo Gallery
Cooling the engine requires a descent flow from the waterpump. If not, the engine would pretty soon be overheated.
Check so the air supply to the blower motor isn't blocked.
nizzehult is offline   Reply With Quote
The Following User Says Thank You to nizzehult For This Useful Post:
pwehr (02-22-2011)
Old 02-22-2011, 09:53 AM   #9 (permalink)
Blower is working fine with plenty of air flow.
Old 02-22-2011, 11:59 AM   #10 (permalink)
Well, it might be operating as it should with high rpm an so, but as long as it isn't supplied with new fresh air from outside the car no major heating would be archived.
Are the in- and outlet tubes that is circulating the water into the car getting warm?
Old 02-22-2011, 01:58 PM   #11 (permalink)
The heater core intake and outlet tubes get warm, but when you take a line off there is no continued water flow.
I'm in the process of changing the water pump,timing belt,thermostat and head gasket while it's all apart. I'll update once it's done.
Old 02-22-2011, 02:01 PM   #12 (permalink)
When replacing the head gasket,Do I need to replace the head bolts on this engine?
Old 02-22-2011, 06:46 PM   #13 (permalink)
blb
View blb's Photo Gallery
The head bolts are not torque-to-yield. They can be reused once.
blb is offline   Reply With Quote
The Following User Says Thank You to blb For This Useful Post:
pwehr (02-22-2011)
Old 02-23-2011, 04:22 AM   #14 (permalink)
OK, then you definately have a water pump issue. If the valve is OK.
Changing timing belt at the same time (and thermostat) seems like a good idea. But the head gasket? Is lt leaking?
Old 02-23-2011, 08:19 AM   #15 (permalink)
I think it has a small leak, blowing water out the exhaust. I've owned this car for only two weeks, so at first I thought the water was condensation from some damp cool nights. There was no water in the oil, but a light residue of oil in the cooling sys. that I thought might have been from a previous repair, because it has a new radiator. Tested the cooling sys. with the blue dye to check for exhaust gases and found none, recently let it idle for several hours and there was a small amount of water under the tail pipe.
I really like the corolla's, but those intake,and water pump tube support bolts must have been designed for small japanese arms only, what a pain in the XXX.
Last time I worked on my own car was 30 years ago, the good old days. Rebuilt my 1964 ford pickup 292 in-line 6 cyl. talk about easy to work on. Did a major overhaul with the engine in the truck. Of Course wouldn't want a furd at fuel prices today.
