Wheel Fitment Assist - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-25-2011, 02:33 AM   #1 (permalink)
SCT
iAzn
SCT's Avatar
Gameroom cash: $316700
View SCT's Photo Gallery
AE92 Wheel Fitment Assist
Ok, wanting my calculations checked. Here's the infos:
MX73 Cressida Steelies
15"x6.5"
12+ Offset
4.25" Backspacing
4x114.3 Bolt Pattern
Going on an AE92 sedan.
Need 4x100>4x114.3 adapters, thinnest I could get is 25mm.
I took the driver side front wheel off. Held the Cressy steelie up to it, centered while the mounting surface of wheel is resting on tip of the studs which where the Cressy steelies will sit when adapters are on.
The center of the Cressy steelie sits fine, nicely flush with the side of the car. However, the wheel barrel itself sticks out about an inch to inch and a half.
Planning on rebarreling the steelies so they would go from +12mm offset to
+37mm, which is a full inch. But could add another 3mm to 7 mm before the edge of the outside wheel barrels go pass the furthest outside point of the wheel center. Pretty much, the rebarreling is just so the wheel barrels don't stick out, obviously.
Doing that would make the backspacing go from 4.25" to 5.25".
Considering the fact that I want a set of Tom's Racing Vesta (15x7, 38+, 4x100), those have a 5.5" backspacing which is about quarter inch more what the Cressy steelies would come up having after the rebarrel. Also, the width is .5" (12.5mm) more.
Assuming that, I can only picture the tires will still clear the rear spring seats and everything else. The wheels would look very decent if not perfect.
Is there anything that I'm overlooking?
I'm buying the adapters now. I'm going to rebarrel only on of the wheels for right now. That way if shit still fails, at least I didn't waste money on the other three *useless* rebarrels.
AE92 GTS Skirts | AE92 LE Trunk Garnish | 4AGZE Cryo-Blueprinted Crank
SCT is offline   Reply With Quote
Old 02-25-2011, 05:34 AM   #2 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $352045
View Flashmn's Photo Gallery
Thats an awfully lot of work for steel wheels Imho. Steelies arent really that special anyways.
Old 02-25-2011, 10:10 AM   #3 (permalink)
Rotary guy...
eage8's Avatar
Gameroom cash: $434050
View eage8's Photo Gallery
why don't you just order steelies from diamond racing
http://diamondracingwheels.com/pro.html
they're like $80-90 per wheel... you get whatever backspace you want, what ever lug pattern you want with whatever width you want....
that has to be cheaper than getting bolt pattern converters and rebarrelling the Cressida wheels.
that's what my 13x8s are... they have a 5" back space (+13 offset):
Here are some 13x8s with 4" back space (-13 offset):
'81 BMW R65
Old 02-25-2011, 07:55 PM   #4 (permalink)
KDM is in
REN69's Avatar
Gameroom cash: $273221
View REN69's Photo Gallery
haha... I like that last pic, nice place to have an autox event... it's not like you'll wake up the neighborhood.
+1 on the diamonds... or try aerowheels.
Old 02-25-2011, 11:05 PM   #5 (permalink)
SCT
iAzn
SCT's Avatar
I think I may have found a new option. I'll let the picture speaks for itself.
Old 02-27-2011, 07:21 PM   #6 (permalink)
KDM is in
REN69's Avatar
I'd hit it... go for it.
http://www.toyotanation.com/forum/forumdisplay.php?f=69
Old 03-01-2011, 12:48 AM   #7 (permalink)
SCT
iAzn
SCT's Avatar
What you guys think? But small problem for the front. I think it'll be fine for the rear, though. The wheel sits further towards the cars' center in the rear than the front. What gives... Unequal POS...
The clean up:
Old 03-01-2011, 05:59 AM   #8 (permalink)
Rotary guy...
eage8's Avatar
most toyotas/fwd cars are like that. Not really sure why.
I put 10mm spacers on my back wheels to even them out.
once you put the car down on tires, it should add some camber and be fine. or you could just get some crash bolts or camber plates and pull the top of the wheel in a little.
looks like they fit nice
'81 BMW R65
Old 03-01-2011, 08:32 PM   #9 (permalink)
SCT
iAzn
SCT's Avatar
It'll clear from contacting the fender lip since my car is not lowered, I hope. But when I get coilovers, I may camber the front and match the rears with spacers and camber them as well. Or I even thought about getting two of the same wheels, if I ever find them, or just the barrels that will make +38 offset and do that only for the front and keep the rear as they are with that +1" lip. They do have +38 offsets for these wheels, I however got negs. Still nice
Old 03-01-2011, 09:08 PM   #10 (permalink)
Rotary guy...
eage8's Avatar
yeah... but if you go over a bump and compress the suspension near max it'll hit the fender pretty hard and probably bend the fender or cut your tire...
'81 BMW R65
Old 03-01-2011, 09:27 PM   #11 (permalink)
SCT
iAzn
SCT's Avatar
I hear ya. Come to think of it, I think the fender lip is still a bit dinged from that one day I had 17's on. Which rubbed the fender lip and wheel well covers behind the wheels when I turned.
I'll have to see. But the wheels are def being gotten.
Old 03-02-2011, 09:53 PM   #12 (permalink)
Gameroom cash: $164205
View kwint's Photo Gallery
I read that different offsets f/r will adversely affect handling. Have you had any problems?
kwint is offline   Reply With Quote
