Wheels - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-04-2011, 11:05 PM   #1 (permalink)
View mpouliot's Photo Gallery
Wheels
Hi, I am getting a 1988 corolla sr5 awd wagon in a few days. I find the wheels small. Can I fit 14 or 15 inch wheels on this car? Thank you. mario
mpouliot is offline   Reply With Quote
Old 03-05-2011, 02:46 AM   #2 (permalink)
ayang951's Avatar
Gameroom cash: $163050
View ayang951's Photo Gallery
you can fit them, just make sure its the rite offset, i hear from the local tire shop that the corollas can run up to +40 offset, but its ideal for +35 and +38... atm on my car im running some del sol rims, that are 14x6 4x100 with some 185/60r14 yokohamas and the rims are a +45 offset, so i had to run rear wheel spacers for them, but i believe that AWD corolla had a different setup, so you might be able to run the offset im not too sure on this though.
"I live my life one corner at a time, for those few seconds or less, im free."
~Mr.Yang
http://www.toyotanation.com/forum/sh...=1#post3365798
ayang951 is offline   Reply With Quote
Old 03-05-2011, 03:24 AM   #3 (permalink)
SCT
iAzn
SCT's Avatar
Gameroom cash: $316700
View SCT's Photo Gallery
15 x 6.5 or 15 x 7. 4x100.
195/50/15 or 205/55/15 tires. Some tire brands have thicker treads so it MAY be an issue. Washers that can go over the studs can fix that just as good as a very thing spacer. 15" wheels with these two spec of tires will keep the original outer circumference of a factory 13" with 175/70/13.
35+ to 45+ offset max can be ran.
This is for a perfect, flush look.
Of course, some like it deep dished and cambered. Or small. Best way to fit is test fit if you don't want the flush perfection.
AE92 GTS Skirts | AE92 LE Trunk Garnish | 4AGZE Cryo-Blueprinted Crank
SCT is offline   Reply With Quote
Old 03-06-2011, 10:07 PM   #4 (permalink)
Canada Wheels
Thanks for the info. I found some early 90's corolla 14 " 4 x 100, 14 x 5.5 , but the offset is +45. I read on one of the forum that the FWD ran a higher offset than a RWD vehicle ( +45 compared to +20 ). I asked a mechanic and he said that in the case of my AWD, I should treat it as a FWD and go with the higher offset ( +45 in this case ). Does that make any sense? Thanks for the info. mario
