Originally Posted by DigGz-AE92z
Wat r rolled fenders?
rolled fenders is when you get rid of your rear or front fender lip. (most the time rear, since the fronts are a bit tricky due to the flimsy front fender design) reason you wanna get rid of the fender lip is because when your car is lowered with lower offset wheels = THUMP!!!! everytime you hit a bump.
http://www.rollyourfender.com/instruction.html
using one of these tools should yeild the best result, (BAD ADVICE->) of course you can use a basball bat or a metal rod, it will do the job also. not as good a job but it works. however with the fender roller you can use one hand to heat the fender paint with a heat gun and one hand to move the roller. its safe for me to say about 90% of the time a fender roller does not break and chip paint when paired properly with a heat gun. a baseball bat or metal rod will chip paint prob most the time, (dont ask me how i know).
this is my car with +25mm 15x8 axis OG's. you should be able to see it, notice how there is no rear fender lip anymore. this is what im talking about.
