1. Sunroof clicking but only moves one inch, and 2. Cleaning door ajar sensor
Hi, sunroof motor seems fine but when I hold the switch it moves back about an inch then makes a loud repetitive clicking. Tried searching but this forum has the worst search tool I have ever encountered on any forum. Am I correct in assuming this is a snapped rubber pulley/belt or something? Should I scavenge the junkyard for another one from a celica/corolla or just buy it new? I would prefer not to take off headliner etc just to diagnose the problem.
Also my passenger side door ajar sensor (for dome light) sticks about half the time, if I want to clean it up/lube it does the rubber cover just pop right off?
Edit also popping a white LED into the ashtray bulb since mine has always been burnt out. Just curious as to whether the ashtray bulb is always on when the cluster/hvac lights are on, or if it only comes on when the tray is open?
