Engine Cooling Issue - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-02-2011, 04:22 PM   #1 (permalink)
View omg370z's Photo Gallery
My stock 88 corolla runs fine, but in stop and go traffic (Only with A/C on) it begins to show higher engine temperatures. The fan still turns on, and I previously replaced thermostat. Any ideas what it could be? Thanks in advance.
omg370z is offline   Reply With Quote
Old 04-02-2011, 06:23 PM   #2 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $352045
View Flashmn's Photo Gallery
Maybe air in the system, thats not really a good sign if the gauge gets higher. I observed that my ECU will see 100+C and the temp gauge hasnt moved anywhere, when theres air in the engine :P
Old 04-03-2011, 09:32 AM   #3 (permalink)
Gameroom cash: $150700
View 90 GP's Photo Gallery
Maybe a clogged radiator and/or water pump on the way out.
90 GP is offline   Reply With Quote
Old 04-04-2011, 09:19 PM   #4 (permalink)
So would I just replace the radiator, or are there some cheaper solutions that might fix the possible problem. I appreciate of all the help guys.
Old 04-05-2011, 07:18 AM   #5 (permalink)
If you have a good radiator shop nearby you could pull it and have it flow checked and rodded. If it's the original might be cheaper to replace. A full cooling system flush and refill with new antifreeze would also be a good idea.
Old 04-05-2011, 10:46 PM   #6 (permalink)
verlaryder's Avatar
View verlaryder's Photo Gallery
Very common problem caused by mineral buildup inside the radiator due to owner use of aftermarket antifreeze mixed with tap water instead of distilled water.
Solution is a new Koyo brand radiator from www.ebay.com for about $130.
Rodding won't be nearly as effective as a new radiator.
My 22 year old 4AF still runs cool because I've always used Toyota brand coolant and distilled water in the system, hence there is zero mineral buildup.
verlaryder is offline   Reply With Quote
Old 04-06-2011, 10:42 PM   #7 (permalink)
Thanks for all the great advice guys.
