If you mean that black, hard rubber ring that goes around the ignition cylinder, it actually pops off the ign cylinder. I never knew that either until I went to a junkyard, cared less about breaking the dash to get what I wanted (the instrument cluster), so yanked the trim panel and that black rubber ring just popped off. I was like "all this time, I've been using a screw driver to get the rubber thing where it should be when I put the trim back on, and THE BITCH JUST POPS OFF!"
I can provide pictures later.
But it just pops off. If you have the trim off already, you can use a small flathead and pry it off the ign cylinder.
AE92 GTS Skirts | AE92 LE Trunk Garnish | 4AGZE Cryo-Blueprinted Crank
