weber 32/36 high idil problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-06-2011, 08:44 PM   #1 (permalink)
View ae924af's Photo Gallery
I have a problem with my idil to my newly installed weber carb. I have capped some of the lines i thought were important but didnt cap all. Should they all be capped? Also is there a way to lower the idil lower than factory setting? When i look at it the idil screw isnt touching the throttle bracket and doesnt want to go back anymore. should I find a way to adjust that or just adjust the idil mixture screw by screwing it in more. Im not actually sure seeing as I have never worked on a carburetor before. I recently just finished putting on a new head gasket and all new gaskets everywhere so I know it isnt a leak from major engine parts.
ae924af is offline   Reply With Quote
Old 04-07-2011, 10:45 PM   #2 (permalink)
Mr. Nice Guy
canadianae92's Avatar
View canadianae92's Photo Gallery
Sounds kinda like a vacuum leak, any fittings after the carb should be sealed. The idle should also be adjustable if thats all it is.
canadianae92 is offline   Reply With Quote
Old 04-07-2011, 11:18 PM   #3 (permalink)
Rotary guy...
eage8's Avatar
Gameroom cash: $434050
View eage8's Photo Gallery
you should cap every vacuum line. Even if they aren't important, they'll cause a vacuum leak which will raise the idle.
'81 BMW R65
Tags
high idil, problem, weber
