If I remember correctly, someone on here put a 7A-FE into an AE92, and used the 4A-FE wiring and ECU.
I think all that was necessary was to swap a distributor from a late model 4A-FE.
The way he did it you loose the protection of the knock sensor, but it works.
Don't hold me to any of this, I am working with an old brain.
I think if you do a search you should find his thread.
It is a pretty old thread so you will need to do a lot of searching.
'88 Corolla, AE92 SR-5, 7A-FE swap/GT-S suspension
'87 Corolla, AE82 FX-16, 4A-GZE swap (autocrosser)
'03 Tundra 4X4 Access Cab, (FX tow vehicle/Home Depot runner)
Modification: Changing something to what you thought it should have been from the start!
