ksport coilovers - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-12-2011, 09:06 PM   #1 (permalink)
View hwndoggy's Photo Gallery
Gen6 ksport coilovers
just did some research on coilovers for my ae91,,from what ive read they seem to be the best option if you want your car to be as low as possible ,,,,but im wondering if theres anything cheaper without too much of a compromise in handling and drivebility.
just to point out that all i wana do to my ae91 is have it low on 16z or maybe 17s,,its not gona be a speed demon but just a cruiser
hwndoggy is offline   Reply With Quote
Old 04-13-2011, 12:27 AM   #2 (permalink)
Raholio's Avatar
Gameroom cash: $154100
View Raholio's Photo Gallery
Hey again!
If you want to lower your corolla the cheapest and most hassle free way to go is with something like super low springs (King's, Dobis), it's about a 2 inch drop. They won't take away anything from drivability and will increase handling. Also you won't need to get a cert.
Also I hope you found your seats
Raholio is offline   Reply With Quote
Old 04-13-2011, 04:02 AM   #3 (permalink)
Gen6
shit thankx man ,,your always at my rescue
so ill be out trying to find the best deal this weekend
cheers man
Old 04-13-2011, 04:08 AM   #4 (permalink)
Gen6
btw just checked out your wagon on cardomain,,looks mean,,sumin different to all the integras and skylines
cant wait to see it after you get it dropped.
and where'd you get your boss kit n steering wheel
Old 04-13-2011, 05:39 AM   #5 (permalink)
Raholio's Avatar
Cheers mate! She a work in progress! I saw some twin sidies I really wanna get for it but its just a matter of getting funds
But the lowering is yet to happen. Hahaha. I need to focus on one thing at a time
As for the boss kit and steering wheel Trademe I think the boss kit was $17 and the wheel $99. If I can find the links I'll post them up
Old 04-13-2011, 08:48 AM   #6 (permalink)
Rotary guy...
eage8's Avatar
Gameroom cash: $434050
View eage8's Photo Gallery
if you want to slam your corolla springs aren't going to cut it... AE92s have crap suspension travel stock so you'll just be riding around on the bump stops. It will ride like crap and handle like crap.
That's why people suggest the k-sports. They have a threaded short stroke damper that increases suspension travel and doesn't decrease it if you lower it more (because your lowering the damper not the bottom spring perch)
if you want a decent drop, try APEX springs. They're under $200 and they're as low as I'd go on stock struts.
'81 BMW R65
Old 04-13-2011, 12:44 PM   #7 (permalink)
rdyzz's Avatar
Gameroom cash: $137500
View rdyzz's Photo Gallery
i have some D-sports up front on my ae92 with softer springs. it rides way nicer than the koni/ground control ever did. if you get these e-bay coilovers ask to see if you can get springs for them that are 1-2 kg softer.
as far as handling goes the thing ive found over the past years of driving is, on the street/autocross level unless you spend major $$$$ it doesnt matter. at these levels what matters is that it just WORKS. you probabally dont posses the skills to take advantage of the 1-2 seconds a $8,000 coilover set would make.
"driving safe doesn't mean driving slow"
91' mr2 with 3rd gen 3sge - SOLD
91' mr2 turbo - SOLD
96'paseo 40mpg DD!!!!!
90' corolla gts smallport engine FS... "levin front conversion" "current project" - BEAMS 3sge in the works
rdyzz is offline   Reply With Quote
Old 04-14-2011, 03:56 PM   #8 (permalink)
View rickytan456's Photo Gallery
Could we use koni yellows with GC sleeves like the honda guys do to slam their cars? Lifetime warranty and easy adjustability, I know several people who wrecked ksport coilovers within a year just with daily driving, no track use. They seem like garbage to me.
rickytan456 is offline   Reply With Quote
Old 04-14-2011, 08:24 PM   #9 (permalink)
Rotary guy...
eage8's Avatar
yeah, but the problem is (and hondas have it to, but probably to a lesser extent). by "slamming" the car you use all the suspension travel. so you driving around on the bump stops.
you can cut or remove the bump stops to gain some travel, but then you might damage the struts...
one thing you could try is getting some koni short stroke race dampers (8611-1257) for the fronts, but you'd have to section the strut housing and weld it back together.
'81 BMW R65
Old 04-15-2011, 06:13 AM   #10 (permalink)
rdyzz's Avatar
theres alot of factor into the slammed look. as eage8 said and from my own personal experiance the ae92 will have maybe 1/2" to 1" of damper travel, fine for small bumps but will be very crude and make you feel like your going to blow the dampers with any bumps or dips on the road thats higher than 2".
the biggest thing to having the slammed look are, what is the rim/tire combo. i used a 195/50/15 on an 8" wheel, its a little streched so the sidewalls look very low. however if i was to switch to a 205/50 or 55 i would have to raise the car maybe 1/2" to keep fenders at 1 finger gap.
if you could find a quality coilover, take the short stroke of those over the factory struts.
Old 07-23-2011, 01:11 AM   #11 (permalink)
coro99a's Avatar
View coro99a's Photo Gallery
Hey I have a 1999 corolla and was wondering how good does the D2 coilovers ride.. because I was thinking about those or the ksports coilovers just trying to get so views
coro99a is offline   Reply With Quote
Old 07-23-2011, 04:21 PM   #12 (permalink)
Donald's Avatar
Gameroom cash: $201420
View Donald's Photo Gallery
My 2c worth. Read the thread at the link below.
K-Sport Coil-overs
I eventually went to Eibach lowering springs with KYB AGXs up front and GR2s in the rear, on my GT-S, and bought another car just to use the K-Sports for autocross. They are great for auto-X, I don't recommend tham for daily road use.
I just wish I could get AGXs for the rear too.
My setup definitely will not slam your car, it only drops it about 1.2"
'88 Corolla, AE92 SR-5, 7A-FE swap/GT-S suspension
'87 Corolla, AE82 FX-16, 4A-GZE swap (autocrosser)
'03 Tundra 4X4 Access Cab, (FX tow vehicle/Home Depot runner)
Modification: Changing something to what you thought it should have been from the start!
Donald is offline   Reply With Quote
