Originally Posted by ser3100
yeah i have a feeling its either an o2 sensor or the coolant temp sensor. Wouldnt that be the same as the thermostat? Reason behind that thought is becuase when my car runs on the freeway it seems that the temp reads lower but when sitting at a stop light or in heavy traffic the temps go up slightly until the engine fan comes on and then it goes back to normal. Correct me if im wrong but doesnt the temp guage normally stay in one spot if the T stat is working correctly?
Yep, the temperature gauge is meant to sit on the halfway mark when the engine is at normal operating temperature. Typically a faulty thermostat wouldn't trigger a CEL, but it's worth replacing anyway. The coolant temperature sensor is part of the housing near the throttle body. If this is faulty then it could cause the same symptoms that a faulty thermostat would.
You can check the sensor by unplugging it and checking that 5 volts is available between the connector terminals by using a digital multimeter. If you're getting 5 volts then you can also check the resistance values between the terminals, which change as the engine heats up.
