How does the GTS 3point strut bar bolt to the firewall? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-14-2011, 03:55 PM   #1 (permalink)
View rickytan456's Photo Gallery
Gen6 How does the GTS 3point strut bar bolt to the firewall?
Hey guys just pulled a GTS strut tower bar from the junkyard, my SR5 has the firewall recesses for where the bar goes, but no holes drilled yet.
Is there a threaded insert or a stud sticking out? Forgot to look closely at how it bolts up. Also my strut tower bolts are 10mm and the GTS are 12mm will this make a difference? It bolts up fine, I was thinking I'll just use washers for the four strut tower bolts.
I searched but couldn't find this info...thanks
rickytan456 is offline   Reply With Quote
Old 04-14-2011, 05:11 PM   #2 (permalink)
Gameroom cash: $347685
View SuperRA's Photo Gallery
I had to walk 50ft to check for you!
The middle bolts in with, well, bolts. They thread into what I presume are threaded inserts. These aren't found on the sedan/SR5 and will have to be added or just use a nut on the other side.
The strut studs on my GTS are definitely not 12mm in diameter, nor do they look like 10mm. I believe they are 8mm which looks to be the same as my sedan.
SuperRA is offline   Reply With Quote
Old 04-14-2011, 06:05 PM   #3 (permalink)
Thanks for checking man, that's weird about the strut bolts...oh well. I'll jsut use a nut on the back like you suggested.
Edit I meant the nut not the bolt...haha
Old 04-14-2011, 06:54 PM   #4 (permalink)
Full Throttle
Kiwi-Corolla's Avatar
Gameroom cash: $953415
iTrader Score: 16 reviews
Yeah just fit the brace, trace around the holes for the firewall, remove the brace, drill the holes and then mount the brace again. I used the original painted bolts on my 7th Gen and used stainless steel Nylock nuts for the back. Just involves removing the wiper arms and lifting up the plastic cowling a bit. Then you just simply hold a spanner on the nut and tighten the bolt with a ratchet.
Old 04-15-2011, 04:28 PM   #5 (permalink)
Oh I think I know what you mean. Yea, just use a washer, it'll be fine.
Old 04-16-2011, 11:52 AM   #6 (permalink)
Gameroom cash: $100200
View SoGosu's Photo Gallery
I am trying to do the same thing. I pulled a strut bar from a GTS and was trying to put it on my SR5.
What is this part? and what did you do with it?
Uploaded with ImageShack.us
SoGosu is offline   Reply With Quote
Old 04-16-2011, 01:17 PM   #7 (permalink)
Oh, I guess most people put the bar on fuel injected cars that don't have that. You can find a suitable location that all the hoses and wires still reach and just re-mount it there. Or even remount it on the bar possibly. Or, it looks like the bar may still fit there with some trimming of that bracket.
Old 04-16-2011, 01:35 PM   #8 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $352045
View Flashmn's Photo Gallery
Seriously, what is that, I never had that on my 4A-F.
Old 04-16-2011, 05:10 PM   #9 (permalink)
Probably some CA emissions crap.
Old 04-16-2011, 11:45 PM   #10 (permalink)
View cEtnA's Photo Gallery
mm i got that on my 1992 LE sedan i haven't no idea what that is too
cEtnA is offline   Reply With Quote
Old 04-17-2011, 11:28 AM   #11 (permalink)
The New Guy
DahnAE92's Avatar
View DahnAE92's Photo Gallery
Looks like a couple of vacuum sensors to me... Unplug them, and if your car idles like a fat kid running a marathon... lol.
1989 Toyota Corolla GT-S
DahnAE92 is offline   Reply With Quote
