brakes???? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-20-2011, 10:21 PM   #1 (permalink)
ERROLAE92's Avatar
View ERROLAE92's Photo Gallery
AE92 brakes????
good people!
I again ... I am a relative novice, help me please ...
I've been thinking of doing an upgrade on the brakes of my car (Toyota Corolla AE92 sedan).
I was considering several options brakes for the rear brakes consider adjusting the fx Corolla AE82, and forward option could be the brakes ae100-110, but I had wanted to adapt the front calipers toyota 4runner 1989, these are 4-piston calipers,
then in that case to adapt the 4-piston, which must take into account, need to change booster and main pump? you will need some base adapter caliper?
if you need an extra part or different base where buy it?
any help is appreciated, and please be very clear as the English that is very basic handling, thanks ...
ERROLAE92 is offline   Reply With Quote
Old 04-21-2011, 12:15 AM   #2 (permalink)
View rickytan456's Photo Gallery
Any decent quality BBKs for the ae92? price is no issue
rickytan456 is offline   Reply With Quote
Old 04-21-2011, 12:17 AM   #3 (permalink)
ERROLAE92's Avatar
link for the BBKs?
Old 04-21-2011, 05:02 PM   #4 (permalink)
I was asking...didn't want to make a new thread for same topic haha
Old 05-03-2011, 02:13 PM   #5 (permalink)
ERROLAE92's Avatar
somebody help me.....
Old 05-03-2011, 02:31 PM   #6 (permalink)
View cEtnA's Photo Gallery
its not really a big brake kit but i know alt of people have done this. grab the front brakes from a corolla/Prizm 1993-2002 you'll need the whole front brake set up these brakes are over all 1/2 wider i believe. I've personally done this swap and am very pleased im gonna be pairing these with slotted brakes and some nice pads
cEtnA is offline   Reply With Quote
Old 05-04-2011, 11:48 AM   #7 (permalink)
ERROLAE92's Avatar
then your recommendation is: make the switch to brake Corolla / Prizm 1994-2000, this change brake fluid quality, vented discs and pads.
would be best?
like this:
Amazon Amazon
Amazon Amazon
Old 05-04-2011, 12:25 PM   #8 (permalink)
ERROLAE92's Avatar
I have a question ... say 94-00 corolla brakes, fit into the AE92, it would be possible to adapt these:
Amazon Amazon
that indicates they are for corolla 1996, if so will it be worth?
Old 05-04-2011, 12:50 PM   #9 (permalink)
Rotary guy...
eage8's Avatar
Gameroom cash: $434050
View eage8's Photo Gallery
why are you upgrading your brakes? for looks or actual performance?
if you just want better performing brakes swapping out the pads will do wonders.
but a set of Hawk HPS pads and call it a day. if you still want more after that do a GT-S rear disc swap w/ proportioning valve and put HPSs back there too.
'81 BMW R65
Old 05-04-2011, 12:53 PM   #10 (permalink)
yea those should fit. remember your taking the whole brake assembly the entire knuckle
Old 05-04-2011, 01:01 PM   #11 (permalink)
like eage8 said it honestly depends on what you want and what you have. for the pair of front brakes off a ae102 it only cost me $40. and i noticed a difference instantly(best bang for my buck). i do have a rear disk conversion in my garage but I've been too lazy to install them .
Old 05-04-2011, 02:03 PM   #12 (permalink)
ERROLAE92's Avatar
in fact it is for performance and security, and if the swap is scheduled to corolla gts brake for the rear,
and if it fits, I'll opt for dual-piston calipers with drilled rotors.
Old 05-04-2011, 02:42 PM   #13 (permalink)
i forgot to add if you do the front ae102 brake conversion you'll need 14" rims
Old 05-04-2011, 03:29 PM   #14 (permalink)
ERROLAE92's Avatar
so there is no problem because I have the gts rims in 14 "
http://carpartswreckersshack.com/blo...-white-002.jpg
Old 05-04-2011, 04:20 PM   #15 (permalink)
Rotary guy...
eage8's Avatar
you don't really need bigger brakes... they aren't going to get you anything except more unsprung weight.
I run stock front brakes and GT-S rear discs on my autocross car just fine.
replace your pads with decent pads and flush your brake fluid and be done.
'81 BMW R65
Tags
ae92, brakes, corolla 1988, upgrade
