wipers wont work - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-22-2011, 10:29 PM   #1 (permalink)
View psychologique's Photo Gallery
wipers wont work
So I'm having some trouble with the wipers on my 89 corolla. They dont work. I checked to see if there was power heading to the wiper motor with a multi meter and got a reading of zero volts. I used to be able to spray a little bit of WD40 on the plug, change the fuse and vola the wipers worked. This is no longer the case. So i tried replacing the plug. Still no volts. When the plug is connected the fuse blows. When the plug is disconnected the fuse does not blow. I'm wondering if perhaps there could be a problem at the switch? Any insights would be very much appreciated. Thanks.
psychologique is offline   Reply With Quote
Old 04-23-2011, 10:20 AM   #2 (permalink)
Gameroom cash: $150700
View 90 GP's Photo Gallery
Might try swapping out the motor. Old one could be frozen up and popping the fuse.
90 GP is offline   Reply With Quote
Old 04-23-2011, 10:15 PM   #3 (permalink)
I'm reluctant to buy a new motor unless I know for sure that's the problem. I'm a bit confused about the zero voltage reading at the plug...makes me think that the problem is elsewhere...
Old 04-23-2011, 10:34 PM   #4 (permalink)
86camota's Avatar
View 86camota's Photo Gallery
do you have enough windsheild wiper fluid?? jk. lol. check the relay under the dash, might be bad and causing the zero reads on the meters
1986 Toyota Camry- sold
1990 Toyota Corolla All-Trac Sedan- rolled over to 200,000 miles.
Honor-Courage-Commitment
HOORAH!!
86camota is offline   Reply With Quote
Old 04-24-2011, 07:57 AM   #5 (permalink)
Here is a link to a wiring diagram for a 90 Corolla (should be similar) for reference if you want to trace circuit.
http://opc.mr2oc.com/online_parts_ca...CorollaFWD.pdf
Old 04-25-2011, 12:52 AM   #6 (permalink)
well...I looked at the wiring diagram for an 89 corolla and looks like the relay and switch are in the same unit....anything in particular I should be looking for??
Old 04-26-2011, 08:22 PM   #7 (permalink)
KDM is in
REN69's Avatar
Gameroom cash: $273221
View REN69's Photo Gallery
scrap yard... buy a used motor and try it out.
