Need some electrical suggestions and help!
Ok so last night I was getting pissed cause my passenger side HID wasn't turnin on. I was about to rip out the bulb and crush it until I found out the headlight connector was cut from one of the wires! So I put it back together, and flipped the lights on and bam! But the question I have , since there are 3 wires, what are the wire colors for ? I know there's a red/ yellow wire and a red/ black and another, what wires are what? One has to be ground one has to be high beam and one is low beam!
Also! I have foglight LED bulbs, it's an h3 bulb, I have it to the fuse box as a power source and connected to a switch just in case I want to turn it off other than that it's always on. well I want to put HIDs on it soon, but I want to know where else would be a good place as a power source ? I really wouldn't like to use the battery cause I would have to keep flipping the switch. Also since I'm used to not turning off the switch since the fuse turns off, I'm afraid they would drain my battery. Or what could I do to connect it and make it turn off by itself!
Thanks TN!
-1991 Corolla Dx - gone :/
-1992 Toyota Camry LE- Restoration Project-FAILED!
-2008 Honda Civic ex Coupe!
