91 geo prizm - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-05-2011, 10:22 AM   #1 (permalink)
View mktgw's Photo Gallery
Gen6 91 geo prizm
Ok now what I,m going crazy. 1.6 EFI engine and after changing the fuel pump, fuel filter, MAP sensor, cold start injector, timing set at 10 degrees BTDC, air flow sensor in the air intake shroud, cleaning the hole just infront of the throttle valve out, I even dumped a can of sea foam in the gas tank this morning and it still dies when you start going from a stop sign or traffic light. Also I ran the battery down before it started this morning. what do I change now or should I just shoot it. Oh and I even replaced all loose and broken vacuum lines.
mktgw is offline   Reply With Quote
Old 05-05-2011, 06:25 PM   #2 (permalink)
Gameroom cash: $150700
View 90 GP's Photo Gallery
Throttle position sensor? Have you checked it for possible trouble codes in computer. They can be present without triggering light. Jumper TE1 and E1 in grey box on left strut tower. Turn ignition to on (engine off) and count flashes of check engine light for codes. Assume you jumpered connector when you reset timing as you are supposed to. Have you checked engine compression? Ignition coil? Ignitor? Chekout Autozones online repair manual for specifics on checking the above.
http://www.troublecodes.net/Toyota/
http://www.autozone.com/autozone/rep...questid=195616
90 GP is offline   Reply With Quote
The Following User Says Thank You to 90 GP For This Useful Post:
mktgw (05-09-2011)
