supercharger kit 1991 ae92 gts - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-06-2011, 12:48 PM   #1 (permalink)
View javier18's Photo Gallery
Does anyone know where i could get a supercharger kit for my 1991 corolla gts redtop?
javier18 is offline   Reply With Quote
Old 05-06-2011, 04:23 PM   #2 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $352045
View Flashmn's Photo Gallery
Yeah, its called a GZE swap.
Old 05-06-2011, 05:46 PM   #3 (permalink)
ayang951's Avatar
Gameroom cash: $163050
View ayang951's Photo Gallery
LoL! i was about to say the same thing... dude the supercharge is awesome, but remember this, the money you spent on the supercharger, you're going to wonder why didn't you just go turbo...
"I live my life one corner at a time, for those few seconds or less, im free."
~Mr.Yang
http://www.toyotanation.com/forum/sh...=1#post3365798
ayang951 is offline   Reply With Quote
Old 05-12-2011, 12:39 PM   #4 (permalink)
rdyzz's Avatar
Gameroom cash: $137500
View rdyzz's Photo Gallery
i had thought about this also, seeing as most 4ag's are not supercharged. going turbo might actually be cheaper and depending on what size and power your looking at, lag might never be an issue.
you could use the harness and supercharger mounting brackets and sc12 from any year supercharger. there are differences however. with the 90-91 smallport i belive the mount and supercharger bypass is different due to the manifold design. i think evo-lucian did supercharge his NA redtop with gze hardware.
or if you were to ever pieace out a supercharged setup on its own id be all custom, aside from what others stated about using the GZE, which might be cheaper then supercharing a NA 4age from scratch. the two things a 4agze does not have that you can do for your own setup is a standalone and a better super charger, maybe a eaton m45 from a mini or even buying a custom twinscrew supercharger. eitherway superchargers are never known for making huge horsepower on 4cly engines. if response is your thing i would actually consider doing the BEAMS 3sge engine setup. it should be on par with a tuned GZE setup.
actually some guy on the mr2 website fitted a twinscrew on a gze setup. http://www.mr2oc.com/showthread.php?t=166542
"driving safe doesn't mean driving slow"
91' mr2 with 3rd gen 3sge - SOLD
91' mr2 turbo - SOLD
96'paseo 40mpg DD!!!!!
90' corolla gts smallport engine FS... "levin front conversion" "current project" - BEAMS 3sge in the works
rdyzz is offline   Reply With Quote
Old 05-12-2011, 03:01 PM   #5 (permalink)
Resident asshole
Flashmn's Avatar
Imho a turbo is more work. Thats from a professional point of view.
Old 05-12-2011, 03:39 PM   #6 (permalink)
Gameroom cash: $134355
the gze will be easier...... because it's done and in a package....
the turbo will make more power but the gze will make more off-idle torque...
since you're in WA.... watch craigslist.... there's a FWD 4agze currently on craigslist for $900
Old 05-13-2011, 07:29 AM   #7 (permalink)
rdyzz's Avatar
i've helped install turbo kits on other cars, and even swapped my own turbo engine into my old mr2. its not professional advice, but im farmilar with what needs to be done.
turboing a NA 4age vs putting supercharged parts on the NA 4age, it close to the same amount of work. lol well thats in my view anyways since to me there isnt much difference since both those mods are external of the engine. i just remember how much i pain it was to unbolt everything from the aw11 gze block while it was in my buddies car....
Old 05-14-2011, 03:27 PM   #8 (permalink)
KDM is in
REN69's Avatar
Gameroom cash: $273221
View REN69's Photo Gallery
Find a wrecked MR2 SC, take the motor and everything... then find a wrecked Previa SC, retrieve the SC14 supercharger and swap it in place of the SC12 on the GZE and you've got yourself a monster in the works.
Old 05-14-2011, 03:49 PM   #9 (permalink)
ayang951's Avatar
there is a guy rite now on club4ag and he is selling a mr2 4agze clip... he wants 1200 for it... about 80k miles
here is the link
http://forums.club4ag.com/zerothread?id=91003
~Mr.Yang
Old 05-14-2011, 08:16 PM   #10 (permalink)
BackYard Engineering
Evo_lucian's Avatar
Gameroom cash: $102535
View Evo_lucian's Photo Gallery
rdyzz you right, did a supercharged 4age using all ae92 4agze hardware and electronics a couple years ago. Honestly unless you can get a 4agze complete swap and do wiring and labour for cheap then IMO supercharging the 4ag with 4agze pieces or turbo are better routes to go.
I was hitting 9 psi with compression ration around 10.6:1. Alot cheaper and easier than a full 4agze swap. pulled harder than any 4age or 4agze i have ever driven to date.
The only thing in life worse than being talked about is not being talked about
My website updated 6/May/11
http://budgetracer.webs.com/
Evo_lucian is offline   Reply With Quote
Old 05-20-2011, 09:48 AM   #11 (permalink)
LOL, my gze setup pulls harder than any gze setup I've driven in or against.... and harder than any 20V I've seen/ridden in. when it had the heavier E series in it it kept up with then passed a stock 2nd gen turbo mr2 at high speeds. with the C series the MR2 is WAY better... much faster down low, just doesn't have the same upper end pull.
mine is in an 87 hardtop mr2.... an ae101 setup, C52 trans from an ae92 gts... with megasquirt 1 v2.2.
this was set up on MS like 6 years ago... I bought the motor for $700, sold the trans it came with for $200, bought the E51 for $400 w/ axles.... MS was around $300 including the relay board..... after random pieces, fluids, etc... to initially set it up to a 4agze took about 3 months of parts gathering/building, about $1400.... didn't have the gze leanout issue...
the e51 got sold for $500.... so if you use a C series you can drastically reduce the cost.
again to the OP.... there's a local gze on craigslist
Tags
corolla, gts, super charger, supercharger
