20V suddenly started to misfire - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-06-2011, 09:18 PM   #1 (permalink)
View Alf6's Photo Gallery
Hi, My recently purchased 1989 Corolla hatch has a Silvertop fitted to it. Last night it developed a horrible miss. It starts and idles well, but when you go above about 2500 - 3000 revs (guessing) it starts to backfire and miss very badly. Back off the revs, and the car seems okay again. Checked this morning and still happening. I will not have a chance until tomorrow (earliest) to look at anything. Just hoping someone can point me in the right direction in which to start.
Thanks in anticipation. Alf.
Alf6 is offline   Reply With Quote
Old 05-06-2011, 11:00 PM   #2 (permalink)
retiredat44's Avatar
View retiredat44's Photo Gallery
while in the dark, very dark garage fire it up and look to see if the wires are shorting around the cap and plugs... chances are the distributor,, inside/outsode is shorting... and bad, and/or bad coils... you may get away with just cap rother wires, plugs, etc.. but if you need a dizzy too, get as high quality lifetime warranty brand...
1989 Toyota Corolla SR5, Carb.
1993 Camry LE
retiredat44 is offline   Reply With Quote
Old 05-11-2011, 08:30 PM   #3 (permalink)
I have looked for any sparks, etc, and can see nothing. I will have to wait until the weekend to look a bit deeper.
Old 05-12-2011, 02:53 PM   #4 (permalink)
ayang951's Avatar
Gameroom cash: $163050
View ayang951's Photo Gallery
is it the MAF? i once had a problem similar to that with my 01 corolla S... it was doing something liek what you were doing, but wouldnt go pass 3000rpm and itll start misfiring and etc etc... i plugged my OBD2 reader on it, and it said MAF and i changed it out and it drove fine again.
"I live my life one corner at a time, for those few seconds or less, im free."
~Mr.Yang
http://www.toyotanation.com/forum/sh...=1#post3365798
ayang951 is offline   Reply With Quote
Old 05-15-2011, 08:56 AM   #5 (permalink)
I now know what - but don't know why.
Finally had time to pull the distributor cap off and ..oops. Two of the 4 contacts on the inside have almost melted away. No cracking of the cap, just the badly corroded, rapidly disappearing contacts. Help me - why did this happen??
Old 05-16-2011, 01:36 AM   #6 (permalink)
Gameroom cash: $168100
View sam333's Photo Gallery
The contacts in the cap wear out, its common .I replace mine every couple of years.
sam333 is offline   Reply With Quote
The Following User Says Thank You to sam333 For This Useful Post:
Alf6 (05-18-2011)
Old 05-18-2011, 08:35 AM   #7 (permalink)
I put a new dizzie cap on - unfortunately nothing solved.
Could it be a blown head gasket?
Old 05-18-2011, 01:26 PM   #8 (permalink)
Rotary guy...
eage8's Avatar
Gameroom cash: $434050
View eage8's Photo Gallery
did you replace the rotor inside the cap too? and the spark plug wires?
'81 BMW R65
Old 05-21-2011, 02:50 AM   #9 (permalink)
Mr. Nice Guy
canadianae92's Avatar
View canadianae92's Photo Gallery
would be good to check the timing
rev it where it missfires and start pulling spark plug wires out, one cylinder at a time until the miss stops(hard to tell) or pulling the plug wire has no/little effect
before you pull the next put back the one you pulled, dont just pull all of them, hope you know what i mean
canadianae92 is offline   Reply With Quote
