Originally Posted by tojones
A bad brake booster would cause the high idle? The brake pedal felt normal even after the car started the idling issue.
The brake booster works with vacuum, so a torn/leaking diaphram or rusted through case could be a source of a vacuum leak.
The fact that the brakes feel good is a good sign that it is not the booster, but not a guarantee.
To be sure, pull the booster vacuum line and plug it. If no change, then that is not it.
'88 Corolla, AE92 SR-5, 7A-FE swap/GT-S suspension
'87 Corolla, AE82 FX-16, 4A-GZE swap (autocrosser)
'03 Tundra 4X4 Access Cab, (FX tow vehicle/Home Depot runner)
Modification: Changing something to what you thought it should have been from the start!
