Took the car to an empty parking lot today and got it all dialed in, not sure what the timing is actually at, I basically turned the distributor counterclockwise all the way and kept turning it clockwise t'ill I found the sweet spot - basically ended up advancing the timing a bit. Tomorrow I will spend some time fine tuning the mixture.
Now this engine is in a dune buggy but the conversion should be the same regardless. I do not have cruise control, A/C, power steering or a brake booster.
Alright so as promised here's the write up:
Here's what comes with the kit, carb, adapter, throttle linkage and air filter. You should also get a fuel pressure regulator.
First off take everything off, the 4 bolts that hold the carb, all the vacuum switches, vacuum lines and rails, egr and modulator - I literally took off EVERYTHING. I plugged all the vacuum ports except 1 for the large canister on the distributor.
Make sure you plug the manifold with a shop towel or something the last thing you want is to drop anything down there. Now would be a good time to get some carb cleaner or something and clean the whole are.
You will still need the carb base and if you're running in cold weather you may or may not want to run power to the heater element - I chose not to since it's a summer car mostly...I also made an egr delete plate (still gotta clean it up and paint a little).
The rest is literally plug and play, bolt the carb an adapter, connect the linkage, connect the 2 vacuum hoses like the diagram above and hook up your fuel pressure regulator (I know mine isn't hooked up in the pics below, I was having trouble with it but it will be back in soon). The engine fired up right away with the baseline setting (given with the kit). I realized when driving that there were a couple flat spots but after playing with the timing it all smoothed out.
Overall I gotta say it was a really simple conversion mostly plug n play. It looks much cleaner and performs waaay better. I haven't had the car on a dyno and it wasn't really running right stock to begin with but the difference is night and day, smooth and pulls hard all the way through.
Hope the write up helps - let me know if you guys have any questions
