well i actually figured out the problem and got them working beautifully for the windows it turns out all you have to do is reset the mini 30 amp breaker thats in the drivers side kick panel above the fuse box just push a pin in all the one you can find one will be the window breaker and it should make a click when reset. now for the door locks if there not working youll have to take the glove box section of your dash off, and on the back of the glove box there may or may not be a door controle module(yellow box) mounted to the back of the glove box, on my car it wasnt there i had to retrieve this from the donor car. The wires that are supposed to connect to the door control module are tied up just to the left of the glove box right to the right of the centre console. jusat cutt them lose and plug them in and yours locks and windows should be working.
-1990 Corolla SR5 Modified, body work done and currently being painted ( Girlfriends car)
-1993 Camry LE Stock with sound system Currently in the process of painting( Moms car)
-1991 Corolla LS Stock with sound system and Audi rims( Dads car)
-1989 Corolla GT-S Modified( My Car)
