7afe block with 4afe head = stock ECU? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-14-2011, 11:24 PM   #1 (permalink)
View G|F.E.A.D|Killa's Photo Gallery
Ok, so i have a thought and i cant find an answer. can i put a 1.8l 7afe block in my DLX with the stock 4afe head, and just not use the knock sensor and run off the stock 4afe ECU. i know the rev will be slightly lower but i will work on that later.
G|F.E.A.D|Killa is offline   Reply With Quote
Old 05-15-2011, 01:50 PM   #2 (permalink)
View yoshiki2's Photo Gallery
Thinking about doing the same. Or installing a 2nd generation 4afe. Would the wiring and Ecu be the same?
yoshiki2 is offline   Reply With Quote
Old 05-16-2011, 03:56 AM   #3 (permalink)
jordanangel's Avatar
View jordanangel's Photo Gallery
why swap head when from what i heard all you need to do is use the distributor from the 4afe and swap the 7afe engine in place of the 4afe
90 Geo Prizm: 4afe 3 speed auto 227k miles, gone to scrap R.I.P CJ
jordanangel is offline   Reply With Quote
Old 05-16-2011, 06:48 PM   #4 (permalink)
Im actually not sure what i need to do to use the stock ECU. im just looking for a mild torque increase without redoing the computer setup as my DLX is gonna get the euro treatment for a different looking corolla till i can get the money for a 1.8L 20v setup
Old 05-16-2011, 08:23 PM   #5 (permalink)
from what i heard the only the 4ag head can swap over to the 7af block, but the 4af doesn't fit ether the 4ag or 7af from what i've heard. like i said from what i've heard the distributor is the only thing that needs to be used from the 4af, i heard the 7af uses the same one, i'm hoping donald or someone will chime in to help on this cuz i'm not sure and donald and bunch of others have done 7afe swaps
Old 05-16-2011, 10:36 PM   #6 (permalink)
ahh i see, i saw that on google but i dont always believe what i see on google lol. so basically i can use a complete 7afe on the stock 4afe wiring harness.?
Old 05-16-2011, 10:41 PM   #7 (permalink)
mounts and transmission would be the same.. wiring harness, ecu different. and you'll have to rewire the whole car... not worthy on my opinion ( had to give up that idea). but a guy told me that the 2nd generation 4afe is a straight swap..
Old 05-16-2011, 10:47 PM   #8 (permalink)
now thats what im intrested in. i have read that the second gen 4afe has better power numbers and a better head design with better cam profiles. anyone else what to comment on this. cause if this is the case i will straight up buy one next week and get it rebuilt and swap it in.
Old 05-17-2011, 05:06 PM   #9 (permalink)
Gameroom cash: $134355
blind leading the blind.
year for year the 4afe and 7afe heads are identical.
if you want to use the 4afe head from your year on a later year 7afe block... there's no reason why you couldn't.
if you really want to have fun use the 4afe pistons in a 7afe with the 4afe (from your year) head... that way you'll have higher compression, more displacement, and you can run the stock electronics.
Old 05-17-2011, 09:41 PM   #10 (permalink)
so a quick recap, using MY 1st gen 4a head, on top of a 7a block, using stock 4a pistons will let me use the stock wiring harness and ECU. i hope thats the truth cause that would be EPIC
Old 05-18-2011, 02:28 AM   #11 (permalink)
if the 4afe head can fit the 7afe block then y can't the 4age head fit the 4afe block when the 4age head fits the 7afe block? cuz from what i've seen on these forums i have seen that everyone says the 4age head will not fit the 4afe block. you could always go to the local parts store and look and at both the 7afe and 4afe head gaskets and see if they are the same
Old 05-18-2011, 01:37 PM   #12 (permalink)
^^ what he said lol. i just want to drop the bigger block in though. not a ge head. dont really wanna swap for that motor as i heard it dosent have as good of low end torque when compared to the 7afe.
Old 05-18-2011, 03:32 PM   #13 (permalink)
OMG you guys are stupid or don't know how to read.
the 4age head WILL fit on a 4afe block. there's no issue there.
the fact is that you DON'T want to do it because the 4afe uses much lower compression pistons. The cylinder chamber on a 4afe is smaller and the piston is dished..... you throw a 4age head, which has a larger combustion chamber, on a dished piston 4afe block and you're sitting at like 7.0:1 compression.
it will bolt together but it won't run well. there's a difference there.
anyone who has said a 4age head won't fit on a 4afe block is stupid. sorry.
the 4afe has slightly less dished pistons than the 7afe (probably due to the 7a's longer stroke).... so if you use the 4afe pistons you'll increase the compression. Since the early 4a and 7a combustion chambers, I would assume, are essentially the same size you wouldn't see a loss in compression using the 4afe head on a 7a block.
almost all of the wiring is through sensors located in the head (or pieces attached to the head).... the computer is smart enough to compensate for the slightly larger displacement.... but if you're concerned just get an aftermarket adjustable FPR and raise pressure a couple PSI.
this stuff isn't rocket science.
The Following User Says Thank You to toyotaspeed90 For This Useful Post:
jordanangel (05-19-2011)
Old 05-18-2011, 09:52 PM   #14 (permalink)
thanks man, glad to actually get a solid answer. looks like i need to start getting a 7afe block built from the ground up.
Old 05-19-2011, 04:45 AM   #15 (permalink)
oh that clears up alot and makes alot of sense
