Originally Posted by G|F.E.A.D|Killa
i agree with the EFI fuse, or pull one of the wires that goes to the distributor and kinda leave it in there, a friend did that to me and it took an hour to figure out what the hell was going on. all it will do is just turn over.
if you're talking about your corolla.....
#1 your coil is internal to the dizzy.... so you can't pull the coil wire
#2 if you pull just 1 spark plug wire, the engine SHOULD run on 3 cylinders.... not happy, but it should
#3 Toyota ignition systems are stout.... they can jump a pretty darn big gap.... if the wire was just close by it should still jump the gap and get spark to the plug....
