i need help - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-22-2011, 02:20 PM   #1 (permalink)
View kingkoopa45011's Photo Gallery
Gen6 i need help
ok guys i have a 89 corolla auto and it was running fine last night and went to go somewhere today and went to go turn it over and nothing everything powered on fine but u do hear a faint click i tried to jump it nothing and also the hood fell and now it wont latch i have it pushed back but it fall hard and now it wont latch please help guys
kingkoopa45011 is offline   Reply With Quote
Old 05-22-2011, 02:33 PM   #2 (permalink)
SCT
iAzn
SCT's Avatar
Gameroom cash: $316600
View SCT's Photo Gallery
If it just click once while you're holding the key to start, then it's likely a ground. If the starter continuously clicks or does nothing (no sound), it could be a bad ground, battery or starter.
Check the battery. Batteries can sometime short on the inside and that can throw everything off.
For the hood latch, it may have damaged the spring to latch it. You can find the same corolla in any junkyards, so I guess you can easily get a replacement there. I'm not sure if there's an adjustment on the latch. If there is, maybe the hood just knocked the adjustment off. I know there are those two rubber contacts on the sides.
AE92 GTS Skirts | AE92 LE Trunk Garnish | 4AGZE Cryo-Blueprinted Crank
SCT is offline   Reply With Quote
Old 05-22-2011, 05:01 PM   #3 (permalink)
Gameroom cash: $150700
View 90 GP's Photo Gallery
For the starter could be solenoid contacts that are worn out. Clean up the batttery terminals/cables with wire brush to make sure have a good enough connection. The starter draws alot of amps and a mediocre connection would operate lights/ etc but not crank the starter. Also can try giving starter a good hit while key in start position. Sometimes that jarring springs it to life. For hood try spraying mechanism with wd40. The latch mechanism is designed to be ajusted up and down (two bolts). Loosen the bolts and move it upward slightly. When it slammed could have moved down enough so that it can't engage .
90 GP is offline   Reply With Quote
Old 05-22-2011, 10:24 PM   #4 (permalink)
Ok i just went out to check the ign fuse and stuff but i tried it again and when i try to turn it over nothing but i notice the clock dims completely out till i quit trying to start the car
Old 05-22-2011, 10:49 PM   #5 (permalink)
SCT
iAzn
SCT's Avatar
When you try to start, it draws power from the battery which would eventually go dead.
Old 05-23-2011, 06:01 AM   #6 (permalink)
The battery may have a dead cell which would explain why it won't take a jump. Pull battery and take to advance or autozone to be checked. If you have to replace it take car back later to get charge system checked. Clean up battery terminals and cables first to rule that out. I have found the slightest bit of corrosion keeps mine from starting.
Old 05-23-2011, 03:36 PM   #7 (permalink)
the barrery as far as i kno is brand new it just got replaces and the leads are fine the pos cable is brand new i mean i can check the ground later its my girlfriends car so i just make her mom pay for it
Old 05-23-2011, 11:05 PM   #8 (permalink)
ok her mom came and jumped it and it fires up every time now
