Transmission removal - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-26-2011, 02:56 PM   #1 (permalink)
Mr.Nutcase's Avatar
View Mr.Nutcase's Photo Gallery
I am going to remove the transaxle/transmission on my 88 Corolla
(Transaxle is the A131L)
To fix the differential..(bearing are bad)
Do I need to remove the "Lower Arm with Crossmember?
Or just the center member?
ECT,EGR,TPS,MAF,CMP,CKP,02,
Mr.Nutcase is offline   Reply With Quote
Old 05-26-2011, 03:55 PM   #2 (permalink)
Gameroom cash: $347685
View SuperRA's Photo Gallery
I could be wrong, but I believe it will be easier to remove the arm with the crossmemeber rather than leaving it in place.
SuperRA is offline   Reply With Quote
Old 05-27-2011, 08:57 PM   #3 (permalink)
blb
View blb's Photo Gallery
All you need to remove is the center member.
blb is offline   Reply With Quote
Old 05-27-2011, 09:23 PM   #4 (permalink)
Mr.Nutcase's Avatar
Good, I dont want to remove the lower control arms with crossember..
That is where I put the jack stands.... as the pinch weld are rusty...
I dont trust them on this car, on my brothers 96 Camry I trust since his not rust buck like mine....(just allittle rust.....
Old 05-28-2011, 04:41 PM   #5 (permalink)
Oh, my mistake, I mis-read the diagram. Yea I don't think you need to remove the arms.
Old 05-30-2011, 10:20 AM   #6 (permalink)
Mr.Nutcase's Avatar
I removed it, not bad.....
You dont need to remove the crossember..
I think 6 bolts for the converter is overkill..
Only 4 bolts to engine....
