help identifying part - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-01-2011, 09:51 AM   #1 (permalink)
Living on a Rock
kaitaiya's Avatar
Gameroom cash: $212950
View kaitaiya's Photo Gallery
anyone know what this part is for? i'm pretty sure it came out of a 88 gts when we stripped the car, but i am not sure where it goes. i'm guessing under the dash but that's a mess currently... googled the part number nadas, same on toyodiy.
any help would be appreciated.. thanks
解体屋 Just a gearhead in paradise...
93 JDM AE102 20V Blacktop Blacktop Wiring DIY
The Somewhat tips and trick to the install
Proper Planning and Preparation Prevents P*** Poor Performance.
kaitaiya is offline   Reply With Quote
Old 06-01-2011, 01:57 PM   #2 (permalink)
Gameroom cash: $347685
View SuperRA's Photo Gallery
It might help to show the whole unit and possibly where it's located?
SuperRA is offline   Reply With Quote
Old 06-01-2011, 02:28 PM   #3 (permalink)
Living on a Rock
kaitaiya's Avatar
Ill get a better pic. It's located on my toolbox hence the reason I'm trying to figure out where it's supposed to go
Old 06-01-2011, 02:37 PM   #4 (permalink)
Rotary guy...
eage8's Avatar
Gameroom cash: $434050
View eage8's Photo Gallery
a picture of the plug might help too...
might be the cruise control computer?
'81 BMW R65
Old 06-01-2011, 07:29 PM   #5 (permalink)
View 4dRcOrOlLA's Photo Gallery
its the ac amplifier module tha sits behind the glove department
4dRcOrOlLA is offline   Reply With Quote
Old 06-01-2011, 08:03 PM   #6 (permalink)
Living on a Rock
kaitaiya's Avatar
Thanks. Just got these 2 pics.
Old 06-01-2011, 08:41 PM   #7 (permalink)
Living on a Rock
kaitaiya's Avatar
By chance would it keep the car from cranking over?
Old 06-02-2011, 05:52 AM   #8 (permalink)
Gameroom cash: $150700
View 90 GP's Photo Gallery
It only controls a/c functions such as compressor engagement and disengagement etc. Shouldn't have any effect on engine starting. Had mine unplugged while checking out evaporator and was able to start my engine.
90 GP is offline   Reply With Quote
Old 06-02-2011, 06:14 AM   #9 (permalink)
Living on a Rock
kaitaiya's Avatar
thanks for the help. guess it's back to figuring out why i don't have crank if i hit the wires going to the starter i can get it to crank. i can hear the relays clicking when i turn the key switch. but something in between. guess i'll recheck the relays and fuses this weekend.
Old 06-02-2011, 07:00 AM   #10 (permalink)
Don't know if you have a 5 speed but if so check the switch on clutch pedal for continuity. If auto try starting in neutral to check if that's an issue. The starter solenoid contacts are notorious for wearing down and causing intermittent no starts. Could also have corrosion on starter terminals. Can buy replacement solenoid contacts at toy dealer and fix inexpensively. Here is link on solenoid rebuild.
http://www.4crawler.com/4x4/CheapTricks/Starter.shtml
Old 06-02-2011, 07:25 AM   #11 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $352045
View Flashmn's Photo Gallery
I dont think theres a starter lock out on the clutch pedal. Never seen it in these
Old 06-02-2011, 08:15 AM   #12 (permalink)
Living on a Rock
kaitaiya's Avatar
thanks, i started with the test probe from the starter and worked back into the car so far. from the harness going to the motor i can trigger the solenoid so it turn over. i can hear the clicks when i turn the switch, but it's something in between i think. either i'm missing something or one of the relays failed or the fuse blew when we had the wrong ignition switch. every time i've tried i did hold the clutch pedal in but i was thinking of shorting it to bypass it. does the ECU need to be bolted to the floor? it's currently floating while i'm still trying to figure this out. we're putting the 16V from a 88 GTS into a 90 wagon. pulled the whole body harness from the GTS and adapting it to the wagon. dash harness was swapped so i'm confused why it didn't work.
there is a continuity switch to disable starter function if the switch isn't pressed in. my 20V swap it's bypassed.
