The hotter it is the worse my car drives
I have a 1998 Corolla that I bought in January with 135,000 miles and it has run great until the last three weeks when the outside temperature is 85+. It will run smooth and shift normal coming to work in the morning, under 80 degrees, but about lunch time after I drive for about 10 minutes it starts to "bog down". It's driving like I've got my foot on the brakes. It gets worse the longer I drive, unless I get over 60 on the freeway. If I get into stop and go traffic it runs like crap again. At first I thought it might be the transmission because Feb to April I did a fluid change, drain and fill 3 times and filled with Mobile 1 Synthetic. I changed the fluid 1 more time last week but it didn't help. This week I got a MAP sensor and it does idle better but I still have the problem within 10 minutes of driving. Almost the only way I can keep it going is if I really get the RPM's up. I just noticed when I got back from lunch the brake pedal has almost no travel and is hard to push (normally not hard) and I'm thinking that has also been happening when it gets hard to drive. As far as pulling codes I didn't think to do that before I replace the MAP and since I replaced the MAP the light has not been on. I took the battery cable off overnight when I did the MAP.
So what I'm I fighting and how do I address it? IAT? TPS?
Thanks
