Help/info with A131L - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-13-2011, 12:42 PM   #1 (permalink)
Mr.Nutcase's Avatar
View Mr.Nutcase's Photo Gallery
I got 10 in- ibs for the pinion,alone
Total preload, I got was 12.5 in- ibs
Is that sound back lash when moving the ring gear?
Toyota calls for the carrier cover:
Sealant: Part No. 08833–00070, THREE BOND 1324
or equivalent
I can I use Red RTV or Loctite?
Should I install the gaskets dry or Indian Gasket Shellac?
the over haul kit, they gave two Intermediate cover gasket, two carrier cover gaskets?
Any reason why?
ECT,EGR,TPS,MAF,CMP,CKP,02,
Mr.Nutcase is offline   Reply With Quote
Old 06-13-2011, 01:27 PM   #2 (permalink)
Gameroom cash: $347685
View SuperRA's Photo Gallery
I've found from (various sources on) the internet that Loctite 242 (blue) is the Three Bond 1324 equivalent. I don't know the reliability of the places I got it from, but Loctite 242 does make sense for the application you are using if for.
I always prefer a gasket sealant (not RTV) with my gaskets, but that's just my preference.
SuperRA is offline   Reply With Quote
Old 06-15-2011, 08:57 AM   #3 (permalink)
Mr.Nutcase's Avatar
I found Napa sells Anaerobic Gasket maker
Old 06-15-2011, 01:26 PM   #4 (permalink)
You were asking two different questions right?
A Three Bond 1324 equivalent (Loctite 242) for the threads.
And if you should use gasket sealer for the gasket?
Just making sure you didn't use one for the other's application. That would be bad.
