brakes/pedal - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-13-2011, 02:26 PM   #1 (permalink)
View eishiba's Photo Gallery
brakes/pedal
My corolla is having an issue you push on the brake and when you get to "almost all the way down" it makes a suction like sound. The pedal goes down really far. There is fluid in the resevoir. If there was a leak couldn't I see bubbles as it sucks air into the lines through the master cylinder and resevoir? I don't remember how to tell if the master cylinder was bad but I thought it had to do with when the car was off and pushing the pedal over and over to build pressure, which it does while its off. They may not have anything to do with testing the master cylinder. haha.
eishiba is offline   Reply With Quote
Old 06-15-2011, 08:55 AM   #2 (permalink)
Mr.Nutcase's Avatar
View Mr.Nutcase's Photo Gallery
Originally Posted by eishiba View Post
My corolla is having an issue you push on the brake and when you get to "almost all the way down" it makes a suction like sound. The pedal goes down really far. There is fluid in the resevoir. If there was a leak couldn't I see bubbles as it sucks air into the lines through the master cylinder and resevoir? """"I don't remember how to tell if the master cylinder was bad but I thought it had to do with when the car was off and pushing the pedal over and over to build pressure, which it does while its off. They may not have anything to do with testing the master cylinder."""""""""""" haha.
Sounds like the master cylinder is bad...
Check the where the booster and master cylinder meet for signs of leakeage...
That is to test the brake booster.....
ECT,EGR,TPS,MAF,CMP,CKP,02,
Mr.Nutcase is offline   Reply With Quote
