AC motor - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-15-2011, 10:52 PM   #1 (permalink)
86camota's Avatar
View 86camota's Photo Gallery
AC motor
so, its hot outside, and it seems the ac blower inside my car has stopped working. i know the ac compressor works because i can here it kick on and when i have the air flow set to "fresh", i can feel cold air coming in, just not being forced out by the fan.
so i was wondering, where is the ac blower and what should i do.
ITS HOT OUTSIDE!!! yes, im in phoenix by the way.
1986 Toyota Camry- sold
1990 Toyota Corolla All-Trac Sedan- rolled over to 200,000 miles.
Honor-Courage-Commitment
HOORAH!!
86camota is offline   Reply With Quote
Old 06-16-2011, 02:31 AM   #2 (permalink)
View eberbs1's Photo Gallery
I had my blower motor stop working and it turns out the blower motor itself was bad and i replaced it with a used one.
But most commonly it is the blower motor resistor witch is located to the lower left of the blower motor (the blower motor is behind the glove box) and the resistor has a 4 prong plug on it and there is one screw to remove it (when removed it has about 3-4 springs on it, if any of the springs are broken then it is bad).
If the resistor looks good then i would drop the blower motor out (4 screws on the bottom) and spin it with your hand and see if it spins easily.
eberbs1 is offline   Reply With Quote
Old 06-16-2011, 12:54 PM   #3 (permalink)
Gameroom cash: $347685
View SuperRA's Photo Gallery
Are all the blower speeds not working?
Yes - It may be the motor, fuse, blower switch, etc.
No - It is most likely the blower resistor.
SuperRA is offline   Reply With Quote
Old 06-16-2011, 04:50 PM   #4 (permalink)
Gameroom cash: $150700
View 90 GP's Photo Gallery
Another possibility to add to the other suggestions is the tripping of the circuit breaker for the fan. Remove passenger kick panel. The circuit breaker has a hole in the top to insert a small screwdriver and press in if it has tripped for whatever reason.
90 GP is offline   Reply With Quote
Old 06-19-2011, 05:24 PM   #5 (permalink)
86camota's Avatar
okay, so i changed out the resistor because it was nasty dirty and covered with dust and other s***. i took the motor out and it worked when i took it out and was holding it with the blower fan facing down. but when i put the motor and blower back in facing up and screwed it back in, it only worked for a while. now would that be the motor or something else. btw, all the wiring looks good.
HOORAH!!
Old 06-19-2011, 05:27 PM   #6 (permalink)
86camota's Avatar
when i was testing it, all the speeds worked.
HOORAH!!
Old 06-19-2011, 06:00 PM   #7 (permalink)
Sounds like the shaft is seizing in the bearing or possibly the brushes are worn.
Old 06-19-2011, 06:55 PM   #8 (permalink)
86camota's Avatar
So... New motor? Because I do not want to take apart any more of the dash then I have to.
HOORAH!!
Old 06-20-2011, 06:03 AM   #9 (permalink)
Either replace blower (NAPA has em for around $69). Will have to remove the squirrel cage from the old one and transfer to the new one. When I did mine I think I had to use crimp style spade terminals to make my electrical connections to the new one. If you want to try to revive the old one you could use electric contact cleaner on contact point for the brushes. Can also lube the upper shaft bearing by putting some light oil in gap between shaft and silver cap. I have a hunch on yours it's the lower bearing and getting to that not so easy.
Old 06-20-2011, 11:18 PM   #10 (permalink)
86camota's Avatar
Im just gonna replace the motor. its too hot to try and fix it.
thanks for all the help everyone.
next thing to fix/find is what bearing is bad in the rear. not sure if its the diff bearing or wheel bearings. :/
HOORAH!!
