brake pedal to the floor help!!!!! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-19-2011, 03:42 AM   #1 (permalink)
jordanangel's Avatar
View jordanangel's Photo Gallery
ok so my brake pedal goes to the floor still after new front cailbers, front pads, rear shoes, rear hardware, drums and master cyl i have bleed the system after doing all this and still goes to the floor with out much effort, could it be in need of wheel cylinders or just rebleed the system i would love to have braking like my buddys 95 geo prizm
90 Geo Prizm: 4afe 3 speed auto 227k miles, gone to scrap R.I.P CJ
jordanangel is offline   Reply With Quote
Old 06-19-2011, 04:35 AM   #2 (permalink)
Gameroom cash: $150700
View 90 GP's Photo Gallery
Check out the condition of the rubber hoses going to calipers, rear wheel cylinders, make sure rear shoes are adjusted properly in the rear and bleed it again. Was it like this prior to all the parts were installed? Could also be a dud master cylinder even though new. Did you get alot of air out when bleeding?
90 GP is offline   Reply With Quote
Old 06-19-2011, 04:42 AM   #3 (permalink)
the hoses look fine no cracks or leaks, it was this way before everything got replaced i i'm thinking about rebleeding them tomorrow if the rain lets up and re checking the rear adjustment again for the 3rd time, idk maybe i'm not adjusting it to were its suppose to be, and yes alot of air did come out i even bench bled the master cyl before putting it in
Old 06-19-2011, 05:03 AM   #4 (permalink)
Check all the metal lines front to back for any wet spots(pin holes) and check and or replace rear wheel cylinders. If you have adjusted rear shoes twice can likely rule that out. Are you bleeding it with a helper or by yourself with a hand held vac pump? If using the hand vac pump suggest using a helper .
Old 06-19-2011, 02:33 PM   #5 (permalink)
i'll check for holes and leaks in the lines, and i do it with a helper everytime, but the last time my helper wasn't a very good listener
Old 06-20-2011, 10:10 AM   #6 (permalink)
Gameroom cash: $134355
was this a problem before you replaced the parts?
Very well could be the master cylinder....
Old 06-20-2011, 11:57 AM   #7 (permalink)
Gameroom cash: $128800
View Sturdavj's Photo Gallery
A couple of questions…
When it failed was it a sudden failure or a gradual loss of stopping/braking ?
Are you seeing (hearing) any air when bleeding the fittings ?
There should be some resistance even with miss-adjusted shoes ?
Have you inspected the mechanical side (linkage) of the pedal to the master cylinder ?
Sturdavj is offline   Reply With Quote
Old 06-27-2011, 03:31 AM   #8 (permalink)
it kinda felt like one day it went farther down then usual, i was starting to think the pedal might be a problem and maybe its not adjusted right, i rebleed the system and it got firmer but still at the same spot as before
Old 07-02-2011, 06:12 AM   #9 (permalink)
blb
View blb's Photo Gallery
Manually adjust the rear brake shoes closer to the drum until you can just hear the slightest rub as you turn the drum by hand.
blb is offline   Reply With Quote
Old 07-03-2011, 03:48 AM   #10 (permalink)
they are at that point so i'm starting to think my linkage is not adjusted right so i'm gonna check that after i finish my neighbors ford f350
