Originally Posted by wacs
SupeRA so even if I remove the boot from the inner joint and remove the joint from the housing as mentioned above, I still will not be able to remove the inner joint off the shaft to replace the boots? I do have a Japanese Corolla. So it appears I may be stuck with replacing the entire shaft. If I cab remove it from the transaxle.
Ok, let's back up a bit. I should have been a bit more specific. Depending which kind of axle you have, you may or may not be able to remove the OUTER CV joint from the axle. That was your original goal I believe.
Saginaw - you can remove the outer CV from axle.
Toyota - it is not so easy.
The INNER CV is a "tulip" style and you should be able to remove that like Flashmn has suggested regardless of the axle origin.
