So, I think my rear diff is making noise, but before i dive into it, I was wondering if anyone had a picture/diagram of how its laid out. The main points of interest are the fill/drain plug for the fluid.
Any and all help is much appreciated.
thanks in advance
1990 toyota corolla all trac(yeah, I typed it. lol)
1986 Toyota Camry- sold
1990 Toyota Corolla All-Trac Sedan- rolled over to 200,000 miles.
Always make sure you can remove the fill plug with no problems before removing the drain plug... other than that, I (or someone else if they beat me to it) can take a pic of the FSM pages with the rear diff info and send it to you. (ToyotaNation doesn't allow anyone to post them publicly in the forum.)
I have a 1988½ FSM, though. Not sure how different the rear diff would be from an 88 to a 90.
Well, after looking at the rear end before tearing it apart, I noticed a nice little drip, (by little, i mean more then id like it to) coming from the brake drum. So i have narrowed it down to 3 things. 1. bad axle seal, 2. bad wheel cylinder, and 3 both.
so since i need to do brakes anyway for the rear, im just going to change both as i change the shoes and drums. ill take some pics and post what goes on when i get to it this payday.
thanks in advance
Sounds like a bearing is going out....
How is the noise? Are you accelerating/dec? or the noise is present al the time?
The noise is present all the time. during accel/dec. My guess since it is leaking gear fluid is the axle seal is bad and causing the wheel bearing to go out.
I'm pretty sure the tranny/transfer case (for a manual tranny) are connected, so that the oil added in fills both. I replaced the oil in mine a while ago, I seem to recall that there are two drains and one fill. Same guidelines / oil as the rear diff that I gave above.
That wheel bearing...
sweetness. thanks again for the help.
And yeah, that bearing was pretty bad
