That rear engine mount! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-22-2011, 11:44 AM   #1 (permalink)
View CorolaLifer's Photo Gallery
Hi,
I'm replacing the four round engine mounts on a '92 with ~ 260K NYC miles on it. (The strip between block and transmission was replaced a while ago.)
How do I get to the one by the firewall?
Do I have to lift the engine?
Move it forward?
It looks like a real pain.
My thanks in advance.
CorolaLifer is offline   Reply With Quote
Old 07-22-2011, 03:48 PM   #2 (permalink)
Blof-fan's Avatar
Gameroom cash: $294850
View Blof-fan's Photo Gallery
It ís a pain.
Many, many before you have have cursed that rear mount.
I think the best way to do it is to drop the subframe where it is mounted to. But you'll have to undo some bolts to get it down
Driving : '92 Toyota T19 Carina E GTi
Repairing : '92 Toyota AE92 Corolla Hatchback GTSi
Restoring : '88 Toyota AE92 Corolla Coupé GT-S
My personal website: http://www.corollaae92gts.nl
Blof-fan is online now   Reply With Quote
Old 07-23-2011, 01:45 AM   #3 (permalink)
SCT
iAzn
SCT's Avatar
Gameroom cash: $316600
View SCT's Photo Gallery
Yep, it's a son of a bitch if you want to replace just that mount. As long as the other mounts are fine, a broken rear mount wouldn't be that bad. My front lower mount has been broken for a long time now, engine still stable enough.
AE92 GTS Skirts | AE92 LE Trunk Garnish | 4AGZE Cryo-Blueprinted Crank
SCT is offline   Reply With Quote
Old 07-25-2011, 04:44 PM   #4 (permalink)
View Prof ozone's Photo Gallery
I just wanted to chime in and say how much I hate that mount as well. It is the most hated part on my car and I'm glad to see I'm not alone. Good luck getting it out.
Prof ozone is offline   Reply With Quote
Old 07-25-2011, 06:08 PM   #5 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $352045
View Flashmn's Photo Gallery
Doesnt look too bad, I never changed it, but the one underneath the engine (transmission moun) is the worst.
Old 07-27-2011, 01:47 PM   #6 (permalink)
View xturfoz's Photo Gallery
i just got done doing a clutch job on my sr5 and that mount gave me @#$##% hell. i just got to the part of unscrewing the bolts on it to make it loose and than i just lifted my whole motor+tranny out to pull that mount off.
xturfoz is offline   Reply With Quote
Old 07-29-2011, 07:20 PM   #7 (permalink)
rdyzz's Avatar
Gameroom cash: $137500
View rdyzz's Photo Gallery
yea agree that mount sucks. you can do a couple of things to make it easyier. 1 slot your center crossmember. 2. cut the dampener of the engine mount (rubberish triangle thingy ontop the mount). even if you dont need to drop the whole subframe, lowing it some will make your life alot easyier. then why take short-long cuts when you can just drop the whole subframe and make ite easyier since if your on your back it will prob be a pain already. the rear mount is and always has been what makes a clutch job on a corolla be instead of a 3hr job turn into a 6hr job.
"driving safe doesn't mean driving slow"
91' mr2 with 3rd gen 3sge - SOLD
91' mr2 turbo - SOLD
96'paseo 40mpg DD!!!!!
90' corolla gts smallport engine FS... "levin front conversion" "current project" - BEAMS 3sge in the works
rdyzz is offline   Reply With Quote
Old 08-04-2011, 04:31 PM   #8 (permalink)
View slack3r's Photo Gallery
I wonder if the guy from toyota who designed it is still alive
slack3r is offline   Reply With Quote
Old 08-13-2011, 11:52 AM   #9 (permalink)
View Rolla88's Photo Gallery
DAmn man I have to change mine as well...now that I know all this I'm considering just leaving it...lol..what to do??
Rolla88 is offline   Reply With Quote
Old 08-19-2011, 12:50 PM   #10 (permalink)
View ToyotaBrendan's Photo Gallery
It is a pain to do here's what i did:
1.Lift vehicle on a lift( or jack) i used a lift at my shop.
2.loosen the engine cradle bolts but do not remove them.(cradle will lower a inch of two)
3.remove the one bolt that holds the engine mount.
4. Use a stiff leg or a screwjack with a 4x4 peice of wood on top (to prevent damage) and position it under the transaxle at its lowest point and adjust the screw jack tightly against the bottom the the trans axle)
5. either lower the lift carefully and slowly onto the screw jack or screw the screw jack up lifting the engine and trans. (also can be done with a jack and a jackstand with big block of wood)
6. use a prybar to spread the space that few extra millimeters to pull out the mount.
7. i may or may not have removed the bracket that bolts onto the engine with 3 bolts...to get it out too but it's been so long i forget either way i think those are a 12 or 14 mm and i used a swivel socket and extension.
When i removed this mount it wasn't to replace it, it was to replace the rack n pinion. (the mount blocks the rack bolts) the most difficult part was this mount of that whole thing.
HOPE THIS HELPS!
1991 Corolla DX 5 Speed
1991 Camaro RS 5 Speed
2006 Tacoma 4.0 TRD Auto
ToyotaBrendan is offline   Reply With Quote
