Removing clear coat - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-25-2011, 01:48 AM   #1 (permalink)
View MauiAL's Photo Gallery
Gen6 Removing clear coat
My '88 ae92 has the clearcoat peeling off and I would like to remove it without totally messing up the paint. Anyone have any suggestions on how to do so?
MauiAL is offline   Reply With Quote
Old 07-25-2011, 11:36 AM   #2 (permalink)
Donald's Avatar
Gameroom cash: $201420
View Donald's Photo Gallery
I am really not sure, but I don't think it can be done.
I think the best you can do is use a plastic scraper and remove the loose edges.
Other than that, a full sanding and repaint is the only way I can see taking care of that.
'88 Corolla, AE92 SR-5, 7A-FE swap/GT-S suspension
'87 Corolla, AE82 FX-16, 4A-GZE swap (autocrosser)
'03 Tundra 4X4 Access Cab, (FX tow vehicle/Home Depot runner)
Modification: Changing something to what you thought it should have been from the start!
Donald is offline   Reply With Quote
Old 07-25-2011, 04:11 PM   #3 (permalink)
blb
View blb's Photo Gallery
Only one way to do this. Prepare the surface by removing all wax, grease, detergent, etc using Prep-Sol or equivalent. Then, wet sand with 400 grit until all clear coat is removed and any loose base coat is removed. Prime any areas that were sanded to bare metal. Then, apply base coat, then apply clear coat. Any short cut will turn into a mess very quickly.
blb is offline   Reply With Quote
Old 07-25-2011, 10:22 PM   #4 (permalink)
Gen6
Thank you folks. You told me what I thought, but was hoping against hope there was some easy miracle way.
Tags
1988, corolla, paint
